Hi All,
I’m having a problem importing a jpeg using r.in.gdal. I’ve done it successfully in the past but I have forgotten what I did. Now when I import a jpeg into an xy location it is just a solid block of color (name.red, name.blue, name.green). I think it has something to do with the g.region settings. My image dimensions are 3648 x 2736 and 180dpi (325MB in size). I tried setting north and east to 2736 and 3648 using g.region with a resolution of 1, but it still doesn’t work. Also, when I use r.in.gdal I extended the region. Does anybody know what I’m doing wrong?
Nick
On Fri, Mar 4, 2011 at 7:11 AM, Rich Shepard <rshepard@appl-ecosys.com> wrote:
Almost there:
GRASS 6.5.svn (Nevada-utm27):~/grassdata > v.in.ascii -b --o
in=/home/rshepard/GIS/data/Nevada/nv_wells.txt out=water_wells format=point
fs=‘|’ skip=1 columns=‘well_log varchar(8), x double precision, y double
precision’ x=2 y=3 z=0 cat=0
Scanning input for column types…
Maximum input row length: 39
Maximum number of columns: 3
Minimum number of columns: 3
Column: 1 type: string length: 8
Column: 2 type: double
Column: 3 type: double
Importing points…
100%
Populating table…
ERROR: Could not close attribute table. The DBMI driver did not accept all
attributesThe source table contains three columns: the well_log ID, utm_easting, and
utm_northing. Seems to me that only the first would be an attribute for the
table. How do I determine what the problem is?Rich
grass-user mailing list
grass-user@lists.osgeo.org
