[GRASS-user] r.in.srtm help, again
I have some bathymetric data from GEBCO which are in .grd format (GMT) so I've tried:
r.in.bin -h in=data.grd out=bati
and I get:
ERROR: North must be north of south
The coordinates of the data are 38n/34n 9w/2e
I've tried too:
r.in.bin input=/home/toni/tmp/38n34n9w2e/38n34n9w2e.grd output=bati north=38 south=34 east=2 west=-9
Using rows=4 cols=11
ATENCIÓN: Bytes do not match File size
ATENCIÓN: File Size 319216 ... Total Bytes 44
ATENCIÓN: Try bytes=7254 or adjusting input parameters
So I tried with bytes=7254 (bytes=7255, bytes=7256) but I never get the right number
Any idea?
TIA
Antonio
so I've tried:
and I get:
I've tried too:
the right number
Any idea?
set the correct rows= and cols= options. Right now it is guessing the
raster resolution is 1 pixel = 1 degree x 1 degree.
note the bytes description; it will mostly always be 1, 2, or 4:
   bytes Number of bytes per cell (1, 2, 4)
           default: 1
Hamish
so I've tried:
and I get:
The coordinates of the data are 38n/34n 9w/2w
I've tried too:
r.in.bin input=/home/toni/tmp/38n34n9w2w/38n34n9w2w.grd output=bati north=38 south=34 east=-2 west=-9
the right number
Any idea?
           default: 1
Hamish
Hamish,
I've made first:
grdinfo 38n34n9w2w.grd
38n34n9w2w.grd: Title: GEBCO One Minute Grid
38n34n9w2w.grd: Command: 1.02
38n34n9w2w.grd: Remark:
38n34n9w2w.grd: Normal node registration used
38n34n9w2w.grd: grdfile format: cs (# 8)
38n34n9w2w.grd: x_min: -9 x_max: -2 x_inc: 0.0166667 name: user_x_unit nx: 421
38n34n9w2w.grd: y_min: 34 y_max: 38 y_inc: 0.0166667 name: user_y_unit ny: 241
38n34n9w2w.grd: z_min: -4060 z_max: 3110 name: user_z_unit
38n34n9w2w.grd: scale_factor: 1 add_offset: 0
So from the nx and ny values above, in GRASS I've tried:
r.in.bin input=/home/toni/tmp/38n34n9w2w/38n34n9w2w.grd output=bati north=38 south=34 east=-2 west=-9 rows=241 cols=421
ATENCIÓN: File Size 203536 ... Total Bytes 101461
ATENCIÓN: Try bytes=2 or adjusting input parameters
So, again:
r.in.bin input=/home/toni/tmp/38n34n9w2w/38n34n9w2w.grd output=bati north=38 south=34 east=-2 west=-9 rows=241 cols=421 bytes=2
ATENCIÓN: File Size 203536 ... Total Bytes 202922
I tried with bytes=1 and bytes=4 but the same problem. The combination of rows, cols and bytes never match the file size: 203536
TIA
Antonio
>> and I get:
>> I've tried too:
HB:
AR:
>> the right number
>> Any idea?
HB:
> the raster resolution is 1 pixel = 1 degree x 1 degree.
AR:
I've made first:
nx: 421
ny: 241
So, again:
241 * 421 * 2 = 202922. Your file has 614 too many bytes. Header info?
I have the GEBCO bathy loaded into a lat/lon location here (sort of),
which I did back in Nov 2005.
Looking through the history I used this method-
Note the .jpg I used does not contain absolute depths.
The .jpg I have is 21601x10801 (1' +1), 6190902 bytes, greyscale.
gdalinfo:
Band 1 Block=21601x1 Type=Byte, ColorInterp=Gray
In a simple XY location:
r.in.gdal in=gebco_bathy.21601x10801.jpg out=gebco_bathy
r.region gebco_bathy n=90 s=-90 e=180 w=-180
g.region rast=gebco_bathy
r.out.mat in=gebco_bathy out=/tmp/grass/gebco_bathy.mat
In a Lat/Lon location:
r.in.mat /tmp/grass/gebco_bathy.mat
r.colors gebco_bathy col=grey
I may have done some adjustment in Matlab, it is too long ago to
remember. Probably I just used r.out.mat and r.in.mat to load the data
into a lat/lon location without "lat>90" type errors. The final z-scale
is 0-255, so that isn't much good for quantitative analysis. At minimum
it needs scaling. Maybe better r.region details to cover the (60*360)+1
too?
<http://www.ngdc.noaa.gov/mgg/gebco/grid/1mingrid.html&gt;
Looking at the "free download" website I give up in a sea of online
registrations and "buy the full CD here". :-/
As an alternative, the etopo2 dataset is pretty nice and includes the 2'
Smith & Sandwell satellite altimetry ocean bathymetry. (See the article in
GRASS Newsletter vol. 1)
Hamish
gdalinfo:
too?
Hamish
What I've done is convertig the .grd file to an xyz one trough grd2xyz. Then in Idirisi, import it, rasterize and export as a Geotiff file. Then in GRASS, import to an xy location the tiff image.
The problem now in GRASS is when trying to make a vector file of the raster one I'm forced to use r.thin first, which erase almost all the data, outputing a blank map.
Antonio
Antonio
