- Grass Version: Grass 6.3RC4 (William K's build)
- MAC OSX Leopard
- Using CURL
- I used the r.in.wms interface, which generated this command line:
r.in.wms output=test mapserver=<private> layers=psma:all srs=EPSG:4326 format=png wmsquery=version=1.1.1 maxcols=1024 maxrows=1024 'wgetoptions=-c -t 5 -nv' 'curloptions=-C - --retry 5 -s -S' method=nearest v=1 --overwrite
The wget options are pre-completed by the r.in.wms UI - should I delete these?
Richard
Richard Chirgwin wrote:
I'm having r.in.wms failing with an error
<path to script>wms.download line 118: eval: -n: invalid option
<path to script>r.in.wms: line 436: eval: -n: invalid option
can you rerun with:
GRASS> g.gisenv set="DEBUG=1"
(set back to 0 to turn off debug messages)
What version of GRASS?
What platform? mac?
Is wget installed or are you using curl?
What command line options were used?
Hamish
____________________________________________________________________________________
Never miss a thing. Make Yahoo your home page. http://www.yahoo.com/r/hs
- MAC OSX Leopard
- Using CURL
srs=EPSG:4326
delete these?
If you like, but they should be ignored if using Curl.
Does the script work if you install wget?
Hamish wrote:
can you rerun with:
To help more I really need to see that debug output. There is a debug
message in wms.download on the line before the one that triggers your
error which echos the attempted eval command. ("g.message -d")
- MAC OSX Leopard
- Using CURL
delete these?
Can't use wget, the remote server uses Curl. I will fetch the debugs for you tomorrow.
RC
Hamish wrote:
can you rerun with:
