The elevation map (be_metric) has minimum and maximum elevations of 45.17
and 51.32 m. This command:
r.lake elev=be_metric water=50 lake=pop coord=2295821.12321,175257.829078
--overwrite
produces the output map with this commentary:
Lake depth from 0.000000 to 4.833561 (specified water level is taken as
zero)
Lake area 357082.807803 square meters
Lake volume 409786.922884 cubic meters
Volume is correct only if lake depth (terrain raster map) is in meters
My interest is in a specific, much smaller area. However, when I re-run
the command with much smaller water_level values there is no output:
r.lake elev=be_metric water=0.01 lake=pop coord=2295821.12321,175257.829078
--overwrite
100%
ERROR: Given water level at seed point is below earth surface. Increase
water level or move seed point.
r.lake elev=be_metric water=0.1 lake=pop coord=2295821.12321,175257.829078
--overwrite
100%
If the entire 36 sq. km. is covered with water when water_level is set to
50 (just below maximum elevation), yet input values of 0.01 and 0.01 are
underground, how do I specify small elevations above that of the 'dam' which
is at an elevation of approximately 48.25m?
Rich
On Thu, Oct 6, 2016 at 6:59 PM, Rich Shepard <rshepard@appl-ecosys.com> wrote:
--overwrite
zero)
--overwrite
100%
--overwrite
100%
I am not exactly sure what are you asking, but water_level is the
absolute level of the water, not relative height above the elevation
of the seed. If you want to use the relative height, user r.what to
query the elevation of the seed and add it to your relative height.
Anna
Rich
grass-user mailing list
grass-user@lists.osgeo.org
On Thu, 6 Oct 2016, Anna Petrášová wrote:
I am not exactly sure what are you asking, but water_level is the absolute
level of the water, not relative height above the elevation of the seed.
If you want to use the relative height, user r.what to query the elevation
Anna,
That's exactly the insight I need and did not get from reading the manual
page. Thanks very much.
Rich
