[GRASS-user] r.le.out subdirectory
I just wanted to try out the r.le.* tools for a simple analysis of habitat patch patterns. In this context, I was not able to find out where this r.le.out subdirectory is located where all the result tables are stored? Should this be a subdirectory within the mapset?
Has anyone used the tools recently on G65 on Linux/Ubuntu?
/johannes
within the mapset?
I'm not sure, maybe relative to the
directory you start the module from.
Try 'mkdir'-ing r.le.out/ first, then
running from pwd. (make sure you have
write permissions there.
Hamish
Indeed. With pwd you can get to know where the r.le.out directory is created. The r.le.para directory with the settings (units size, units form, etc) is also created there.
Miguel
2013/6/20 Hamish <hamish_b@yahoo.com>
within the mapset?
I’m not sure, maybe relative to the
Try ‘mkdir’-ing r.le.out/ first, then
Hamish
grass-user mailing list
grass-user@lists.osgeo.org
Thank you for the fast response. It is indeed the pwd.
/Johannes
On Thu, Jun 20, 2013 at 2:44 PM, José Miguel Barrios <jmbarriosg@gmail.com> wrote:
Miguel
within the mapset?
Hamish
