[GRASS-user] r.le Problem
I have some problem with r.le.pixel. When I am trying to use this modul,
with my raster layer as background and another raster layer as sampling area
(ca. 207 squares, 300x300m). Resolution of both layers is 1m, the program
after few minutes computing prints error: "G_calloc: out of memory
r.le.pixel is working..."
From this time happend nothing more. I had take a look in System monitor and
system memory is during calculation enough. Another module like r.le.pach
does work correct with the same dataset.
Thanks
Martin
View this message in context: http://www.nabble.com/r.le-Problem-tf4220376.html#a12006119
have you tried r.li? if it can solve your problem, it will probably do
faster and in a more flexible way.
pc
Martin_Besta ha scritto:
Thanks
Martin
Paolo Cavallini, see: http://www.faunalia.it/pc
