Patrick Giraudoux wrote:
>> Enter name of site map
>> Enter 'list' for a list of existing vector files
>> Hit RETURN to cancel request
>>> sites5
>> <sites5>
>> WARNING: Adapted sites library used for vector points (module should be
>> updated to GRASS 6 vector library).
>> ERROR: G_get_site() not yet updated.
Hm... This is quite strange. I have removed grass and then re-install
6.2.3 completely. No success at all and still this frustrating message:
I really wonder what the origin can be. I have re-installed thinking
that some library could have escaped for some reason during a former
updating. This ws obviously not the case since complete intallation does
not fix the problem. I have also tried other mapsets... with the same
result.
r.le.setup was not fully ported from GRASS 5. GRASS 5's "sites" format was
independent from its vector lines/areas format. In GRASS 6 these were merged.
To ease the change the GRASS 5 sites library was partially adapted to work with
GRASS 6 vectors, but as you are finding not fully.
Fortunately it is not hard to update r.le.setup, patch attached.
My system is Ubuntu Gusty. Wonder if it could come from that ???
No, it affects everyone.
Maciek:
> FWIW this stage works for me with current GRASS 6.2 CVS and
> GRASS 6.3 CVS.
spearfish example:
r.le.setup map=elevation.dem vect=archsites
Setup sampling units (3)
Use keyboard to enter sampling unit dimensions (1)
How many different SCALES do you want (1-15)? 1
Centered over sites 5
Do you want to sample using rectangles
(including squares) (y) or circles (n)? (y/n) [y] y
Sampling unit SHAPE (aspect ratio, #cols/#rows) expressed as real number
(e.g., 10 cols/5 rows = 2.0) for sampling units of scale 1? 1.0
What size (in pixels) for each sampling unit of scale 1? 50
The nearest size is 7 cells wide X 7 cells high = 49 cells
Is this SIZE OK? (y/n) [y] y
archsites
Hamish
____________________________________________________________________________________
Never miss a thing. Make Yahoo your home page.
http://www.yahoo.com/r/hs
(attachments)
rle_setup_sample_points.diff (3.16 KB)
