I want to use the r.li module in grass with a circular moving window to calculate the Shannon index,
but I need to have a window of 1 km2 so I need of a not integer radius.
This seems not possible, any suggestion to do that?
Do you refer to the choices in "Definition of creation of sampling area:"
- Whole map layer: use entire area selected above,
- Regions: select one to many subareas via mouse,
- Sample units: automated selection of sampling area (for details see below)
- Random nonoverlapping,
Do you refer to the choices in “Definition of creation of sampling area:”
Ok Markus, I’ll check it in GRASS GIS 7 as soon as possible!
There in another problem now, if I try to run r.li.shannon, r.li.simpson or other r.li module of r.li suite
with a circulare moving window I get the error
“Illegal areas disposition”
I’ve searched and there is a fixed ticked, #2327, but for Windows OS and GRASS GIS 7
So, here my steps with GRASS 7:
I used the North Carolina mapset, I chose the raster map landuse96_28m and set the region to this map
setup for r.li module: create new configuration file for r.li module
Select maps and define name
Name for new configuration file to create circmw
Raster map to use to select areas landuse96_28m@PERMANENT
Define sampling region(region for analysis Whole map layer https://www.dropbox.com/s/kbbm5udk81rwwsn/r_li_shannon.png?dl=0
Hi Markus, I tried to install grass 7.1 but I get this error
Scaricamento di:1 http://ppa.launchpad.net/grass/grass-devel/ubuntu/ precise/main grass70-core amd64 7.0.0+0ubuntu3~develppa~2~svn-30303~ubuntu12.04.1 [8330 kB]
Scaricamento di:2 http://ppa.launchpad.net/grass/grass-devel/ubuntu/ precise/main grass70-gui amd64 7.0.0+0ubuntu3~develppa~2~svn-30303~ubuntu12.04.1 [2100 kB]
Scaricamento di:3 http://ppa.launchpad.net/grass/grass-devel/ubuntu/ precise/main grass70 all 7.0.0+0ubuntu3~develppa~2~svn-30303~ubuntu12.04.1 [12,8 kB]
Scaricamento di:4 http://ppa.launchpad.net/grass/grass-devel/ubuntu/ precise/main grass70-doc all 7.0.0+0ubuntu3~develppa~2~svn-30303~ubuntu12.04.1 [9177 kB]
Recuperati 19,6 MB in 27s (725 kB/s)
Selezionato il pacchetto grass70-core non precedentemente selezionato.
(Lettura del database… 406788 file e directory attualmente installati.)
Estrazione di grass70-core (da …/grass70-core_7.0.0+0ubuntu3~develppa~2~svn-30303~ubuntu12.04.1_amd64.deb)…
Selezionato il pacchetto grass70-gui non precedentemente selezionato.
Estrazione di grass70-gui (da …/grass70-gui_7.0.0+0ubuntu3~develppa~2~svn-30303~ubuntu12.04.1_amd64.deb)…
Selezionato il pacchetto grass70 non precedentemente selezionato.
Estrazione di grass70 (da …/grass70_7.0.0+0ubuntu3~develppa~2~svn-30303~ubuntu12.04.1_all.deb)…
Selezionato il pacchetto grass70-doc non precedentemente selezionato.
Estrazione di grass70-doc (da …/grass70-doc_7.0.0+0ubuntu3~develppa~2~svn-30303~ubuntu12.04.1_all.deb)…
dpkg: errore nell’elaborare /var/cache/apt/archives/grass70-doc_7.0.0+0ubuntu3~develppa~2~svn-30303~ubuntu12.04.1_all.deb (–unpack):
tentata sovrascrittura di “/usr/share/man/man1/v.surf.rst.1grass.gz” presente anche nel pacchetto grass-doc 6.4.4-2~precise4
dpkg-deb: errore: il sottoprocesso paste è stato terminato dal segnale (Pipe interrotta)
Elaborazione dei trigger per bamfdaemon…
Rebuilding /usr/share/applications/bamf.index…
Elaborazione dei trigger per desktop-file-utils…
Elaborazione dei trigger per gnome-menus…
Elaborazione dei trigger per hicolor-icon-theme…
Elaborazione dei trigger per man-db…
Elaborazione dei trigger per doc-base…
Si sono verificati degli errori nell’elaborazione:
E: Sub-process /usr/bin/dpkg returned an error code (1)
