Hello to everybody,
i tried to run r.li.mps module in order to perform mean patch size index over a raster map. I used a raster with 4 values (1,2,3,4) rapresenting different Land cover types. Some areas in my raster have nodata, since i’m not planning to consider those in my work. I created the configuration file, reported below:
SAMPLINGFRAME 0|0|1|1
SAMPLEAREA 0.0|0.0|1.0|0.9999541221268982
then i run the module over my raster, and here is the output:
RESULT 1|-7.1291406991691
I was not expecting this output, i can’t figure out what’s wrong.
Il tuo 5 diventa 1000
Fai crescere la tua università
Dona il 5 per mille alla Sapienza
Codice fiscale: 80209930587
https://www.uniroma1.it/it/pagina/fai-crescere-la-tua-universita-con-il-cinque-mille
