[GRASS-user] r.mapcal sintax error
i'm in trouble using r.mapcalc in Grass 6.5 svn
In order to replace in a raster map (basin_10m) the values 24,26 with 28, i use the following cmd line:
r.mapcalc 'basin_10m_2=if(basin_10m==24),28'
r.mapcalc 'basin_10m_2=if(basin_10m==26),28'
the result is:
syntax error, unexpected ',', expecting $end
Parse error
which is the correct command to use?
Thank you in advance.
margherita
Ing. Margherita Di Leo
Ph.D. Student Methods and Technologies for Environmental Monitoring
Department of Environmental Engineering and Physics (DIFA)
University of Basilicata Campus Macchia Romana
85100 - Potenza Italy
Office: +39-0971205363
Fax: +39-0971205160
E-mail: dileomargherita AT gmail DOT com
Skype: dileomargherita
URL: http://www.difa.unibas.it/A_Manager_PP.do?azione=visualizzaHomePage&id=106
On Sat, Apr 11, 2009 at 10:00 PM, Margherita Di Leo <diregola@gmail.com> wrote:
You need to set the braces correctly (personally, I use
double quotes to be able to use shell variables). Also
better define the "else" part:
     if(condition, then, else)
so
r.mapcalc "basin_10m_2=if(basin_10m==24, 28, null())"
r.mapcalc "basin_10m_3=if(basin_10m==26, 28, null())"
Note that I changed the second map name to _3 otherwise
it would overwrite the first.
You can also combine conditions, e.g.:
     if(condition1 && condition2, then, else)
cheers
On Sat, Apr 11, 2009 at 10:29 PM, Margherita Di Leo <diregola@gmail.com> wrote:
the matter is that i don't want to replace the whole map with null value , i
only want to replace 24 and 26 with 28 and preserve the other values of the
map.
Sure, then (to preserve, use the map name):
r.mapcalc "basin_10m_2=if(basin_10m==24, 28, basin_10m)"
r.mapcalc "basin_10m_3=if(basin_10m_2==26, 28, basin_10m_2)"
or simply
r.mapcalc "basin_10m_2=if(basin_10m==24 || basin_10m==26, 28, basin_10m)"
