[GRASS-user] r.mapcalc appears to have changed behavior
I had made a number of scripts that worked fine in the 6.4.0 build 6 but appear to have problems with the same code in later revisions:
The method used to take about 6-8 secs and produce about what you would expect on the screen. Now the same calculation takes 0 seconds the file is radically changed. See the before and after below.
Any help would be greatly appreciated.
Thanks
Jim Mochel
r.mapcalc na_dem_sub_20 = na_dem_input - 20
| Layer: na_dem Date: Sat Sep 24 17:37:59 2011 |
| Mapset: PERMANENT Login of Creator: jmochel |
| DataBase: /home/jmochel/grassdata |
| Title: ( na_dem ) |
Timestamp: none
Type of Map: raster Number of Categories: 65535
Data Type: CELL
Rows: 8384
Columns: 9102
Total Cells: 76311168
Projection: x,y
N: 4384500 S: -3999500 Res: 1000
E: 4639500 W: -4462500 Res: 1000
Range of data: min = 0 max = 65535
Data Description:
generated by r.in.gdal
Comments:
r.in.gdal input=“/home/jmochel/gis/raw-data/hydo1k/na_dem.bil” outpu\
t=“na_dem”
r.info map=na_dem_sub_20
| Layer: na_dem_sub_20 Date: Mon Sep 26 23:06:03 2011 |
| Title: ( na_dem_sub_20 ) |
Timestamp: none
Type of Map: raster Number of Categories: 610
Data Type: CELL
Rows: 1
Columns: 1
Total Cells: 1
Projection: x,y
N: 1 S: 0 Res: 1
E: 1 W: 0 Res: 1
Range of data: min = 610 max = 610
Data Description:
generated by r.mapcalc
Comments:
na_dem_input@PERMANENT - 20
