It looks like for the 2nd calculation, your computational region is set to extents of 0W - 1E, 0S - 1N, with a resolution of 1.
So r.mapcalc is only operating on a single 1x1 cell that is outside the area of your raster map.
Michael
____________________
C. Michael Barton
Arizona State University
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Sep 27, 2011, at 11:50 PM, <grass-user-request@lists.osgeo.org> <grass-user-request@lists.osgeo.org> wrote:
Date: Mon, 26 Sep 2011 23:19:11 -0400
Subject: [GRASS-user] r.mapcalc appears to have changed behavior
To: grass-user@lists.osgeo.org
Message-ID:
<CAE=Y9-Q7tFZ=cJ4TC6nceYA5B=R9E7RRwZbVfF_fYbMNTEpC6A@mail.gmail.com>
Content-Type: text/plain; charset="iso-8859-1"I had made a number of scripts that worked fine in the 6.4.0 build 6 but
appear to have problems with the same code in later revisions:The method used to take about 6-8 secs and produce about what you would
expect on the screen. Now the same calculation takes 0 seconds the file is
radically changed. See the before and after below.Any help would be greatly appreciated.
Thanks
Jim Mochelr.mapcalc na_dem_sub_20 = na_dem_input - 20
| Layer: na_dem Date: Sat Sep 24 17:37:59 2011
| Mapset: PERMANENT Login of Creator: jmochel
| DataBase: /home/jmochel/grassdata
| Title: ( na_dem )
| Timestamp: none
| Type of Map: raster Number of Categories: 65535
| Data Type: CELL
| Rows: 8384
| Columns: 9102
| Total Cells: 76311168
| Projection: x,y
| N: 4384500 S: -3999500 Res: 1000
| E: 4639500 W: -4462500 Res: 1000
| Range of data: min = 0 max = 65535
| Data Description:
| generated by r.in.gdal
| Comments:
| r.in.gdal input="/home/jmochel/gis/raw-data/hydo1k/na_dem.bil" outpu\
| t="na_dem"
+----------------------------------------------------------------------------+r.info map=na_dem_sub_20
| Layer: na_dem_sub_20 Date: Mon Sep 26 23:06:03 2011
| Title: ( na_dem_sub_20 )
| Timestamp: none
| Type of Map: raster Number of Categories: 610
| Data Type: CELL
| Rows: 1
| Columns: 1
| Total Cells: 1
| Projection: x,y
| N: 1 S: 0 Res: 1
| E: 1 W: 0 Res: 1
| Range of data: min = 610 max = 610
| Data Description:
| generated by r.mapcalc
| Comments:
| na_dem_input@PERMANENT - 20
