Dear Grass Users,
I have a large georeferenced digital map.
I successfully imported it into GRASS.
Now I would like to "cut" only a small rectangle -- my investigation
area -- out of this large map.
I used the following approach:
1) import the TIFF
2) select the part of interest in the GRASS monitor
3) set the zoomed area as region (monitor tools)
4) create a boundary vector: v.in.region
5) convert boundary raster to a raster v.to.rast
6) use r.mapcalc to cut: r.mapcalc "cut=if(boundary_raster, large_map,
null())"
This works well for the cutting. But the color table of the large input
map is lost resulting in a strange coloring.
Opened in QGIS, it shows me that there is a "color map" associated with
the layer.
How do I get the same color table in the r.mapcalc result?
Thanks in advance,
Timmie
- import the TIFF
- select the part of interest in the GRASS monitor
- set the zoomed area as region (monitor tools)
At this point r.resamp
The output map will match region boundary and resolution with the same category values and color table of the original map.
Pablo.
Novo Windows 7: Seu computador mais simples e fácil. Conheça!
A vida na frente do computador ficou mais simples: Chegou Windows 7! Clique e Conheça
Tim Michelsen wrote:
Dear Grass Users,
1) import the TIFF
null())"
the layer.
Thanks in advance,
Timmie
You can use r.colors' raster option to copy the colour rules over from your original layer.
r.colors map=cut raster=large_map
-- Dan.
1) import the TIFF
null())"
Replace step 6 with:
g.copy rast=boundary_raster,MASK
r.resample input=large_map output=cut
g.remove rast=MASK
the layer.
You can copy the colour table over with e.g.:
1) import the TIFF
null())"
g.remove rast=MASK
Can someone perhaps explain why steps 4 and 5 are necessary?
(My understanding is that r.mapcalc anyway observes the region settings)
Couldn't step 6 be simplified to: r.mapcalc cut = large_map
Hermann
First,
thanks to all who responded. I will try and apply that later.
null())"
g.remove rast=MASK
I don't know. That was the approach I have always seen and been told.
The question is:
when do I use r.resample and when do I use r.mapcalc to cut a smaller
portion from a large raster map?
from the man page:
The method by which resampling is conducted is "nearest neighbor" (see
r.neighbors). The resulting raster map layer will have the same
resolution as the resolution of the current geographic region (set using
g.region).
I actually do not want to extract by sampling than rather copy a smaller
area from the large map.
It would be nice to receive a best practice confirmation on this by a
GRASS power user.
Is there a "best practice page" in the wiki where this could be added?
Thanks in advance,
Timmie
>> 1) import the TIFF
>> null())"
> g.remove rast=MASK
I wasn't paying attention. For a rectangular area, you can just change
the region then make a copy with r.resample or r.mapcalc. I was
assuming an arbitrary (not necessarily rectangular) region.
For a rectangular region, steps 3 through 6 can be replaced with a
single call to r.resample.
Which is equivalent to "r.resample in=large_map out=cut". Using
r.resample is probably more convenient from the GUI, as you can select
the input from a list.
>>> null())"
>> g.remove rast=MASK
The question is:
"r.mapcalc 'cut = large_map'" is equivalent to "r.resample in=large_map out=cut".
from the man page:
g.region).
If the current region has the same resolution as the input map, then
there will be a 1:1 correspondence between input cells and output
cells.
All raster modules perform nearest-neighbour resampling, as the
underlying GRASS libraries automatically resample input maps to the
current region.
The modules which perform other types of resampling (r.resamp.interp,
r.resamp.stats, r.resamp.rst) set the current region resolution and
alignment to match the input map, making the nearest-neighbour
resampling step a no-op.
