Hi everyone.
I have two questions
1)
I have some raster (with the same format and are converted from vector). The
cells have the value of CAT. So the value = CAT
With r.mapcalc I would define a map of output that I give, as the value for
each cell, indications of the different CAT. For example, if I have the
raster A that has value = 1 and raster B that has value = 2, I will have
raster C output value = 1,2
If I have 3 maps in input, value = 1,2,3 etc. ...
I made several attempts but I do not know if r.mapcalc concatenates the
values.
2)
if r.mapcalc is not possible, I tried to make the transition to vector. The
passages that I made are:
- r.to.vect maps raster input (es rasterA and rasterB)
- V.overlay and I get in dbf, in a column the value of rasterA and in
another column the value of rasterB. I've created a third column to
concatenate the 2 columns but it seems to me that the operator '| |' does
not work with dbf.
How do I concatenate the values in 2 columns?
Thank you very much
Gabriele
View this message in context: http://www.nabble.com/r.mapcalc-concatenates-values--tp19392795p19392795.html
If I unterstood you right, maybe r.cross is useful...
Christian.
Zitat von "Gabriele N." <gis.gn@libero.it>:
Hi everyone.
1)
values.
2)
not work with dbf.
Thank you very much
Gabriele
grass-user mailing list
grass-user@lists.osgeo.org
This mail was sent through http://webmail.uni-jena.de
Hi Gabriele,
After you use r.cross (I follow Christian´s suggestion on it), if you need to do some computation with the new generated raster map, you can use r.stats to generate a ascii output. After I even use R to haldle the tabular data.
miltinho astronauta
brazil
2008/9/9 Christian Schwartze <Christian.Schwartze@uni-jena.de>
If I unterstood you right, maybe r.cross is useful…
Christian.
Zitat von “Gabriele N.” <gis.gn@libero.it>:
Hi everyone.
If I have 3 maps in input, value = 1,2,3 etc. …
values.
another column the value of rasterB. I’ve created a third column to
concatenate the 2 columns but it seems to me that the operator ‘| |’ does
not work with dbf.
Thank you very much
Gabriele
http://www.nabble.com/r.mapcalc-concatenates-values–tp19392795p19392795.html
Ciao Christian, Ciao Miltinho
I tried r.cross and is useful. The problem however is that you may need to
concatenate values other than categories (eg .. values with letters A, B, C.
..). In addition, I am working with a script in BASH within a cycle and maps
(equal to counter '$ i') are always more than 10.
I do not know how to put all the maps in input to r.cross and insert maximum
10
while [ $i -le $num ]
do
r.cross input=map$i,map$i+1$i,map$i+2....... output=map_tot
Maybe there will be a more simple (?)
Thank you
Miltinho Astronauta wrote:
Hi Gabriele,
tabular
data.
miltinho astronauta
brazil
Christian.
> Hi everyone.
> 1)
vector).
The
for
have
> values.
> 2)
The
does
> not work with dbf.
> Thank you very much
> Gabriele
View this message in context: http://www.nabble.com/r.mapcalc-concatenates-values--tp19392795p19408709.html
