[GRASS-user] r.mapcalc median filters entire map instead of only null values
I'm trying to use r.neighbors and r.mapcalc in a script to fill holes in a raster where there are null values. A temporary raster is created with r.neighbors that contains a 3x3 median-interpolated surface of the primary DEM. r.mapcalc should only use the value in this temporary raster where a null value occurs in the primary DEM.
Here's the relevant section from my script:
# Procedure for filling nulls with multiple median filter passes
if [ "$PASSES" -gt 1 ] ; then
COUNT=1
while [ "$COUNT" -le "$PASSES" ] ; do
  r.neighbors --o input=${MAP} output=fill.tmp method=median size=3
  r.mapcalc "${MAP}_fill = if(isnull(${MAP}), fill.tmp, ${MAP})"
  MAP=${MAP}_fill
  COUNT=$(($COUNT + 1))
  g.remove rast=fill.tmp
done
else
echo ""
r.mapcalc "${MAP}_fill = if(isnull("$MAP"), fill.tmp, "$MAP")"
MAP=${MAP}_fill
fi
My problem is that when my script is run, the output $MAP_fill raster has it's entire surface smoothed with the median-filtered one, not just the null values like I intended. But if I run the r.neighbors and r.mapcalc lines in isolation outside of the script, I get the intended null-filled DEM with no unwanted smoothing. Am I not quoting the r.mapcalc line properly?
FWIW, I've also tried different quoting methods for the r.mapcalc line, with the same problem occurring each time:
r.mapcalc ${MAP}_fill = "if(isnull($"MAP"), fill.tmp, $"MAP")"
r.mapcalc ${MAP}_fill = "if(isnull($MAP), fill.tmp, $MAP)"
Any ideas?
~ Eric.
COUNT=1
  MAP=${MAP}_fill
done
else
echo ""
MAP=${MAP}_fill
fi
FWIW, the above script (with PASSES=5 and MAP set to a test map) works
fine for me; the non-null cells remain untouched.
No, both r.mapcalc commands are fine.
This is bogus.
Either of these should work.
r.mapcalc simply concatenates all of its arguments, with spaces in
between. Usually, it's best to quote the entire expression with double
quotes.
You only need to use braces around a variable name if the substitution
is immediately followed by a character which is valid as part of a
variable name, e.g. ${MAP}_fill. Adding braces where they aren't
required is harmless.
Thanks for checking the script code, Glynn. I'm going to have to investigate what's going on locally on my machine.
~ Eric.
-----Original Message-----
To: Patton, Eric
Cc: grassuser@grass.itc.it
Sent: 1/17/2007 3:23 PM
Subject: Re: [GRASS-user] r.mapcalc median filters entire map instead of onlynull values
COUNT=1
  MAP=${MAP}_fill
done
else
echo ""
MAP=${MAP}_fill
fi
This is bogus.
quotes.
perhaps modify/extend the r.fillnulls script? A flag to use an alternate
interpolation technique might be nice.
Hamish
It's ok, Glynn tested the script out and it worked for him, so I can't
explain what was happening. My script even works for me now. User error,
I guess :wink:
I didn't know r.fillnulls was a script, as I've never used it before.
Maybe I could take a look at using other interpolation methods as you
suggest.
~ Eric.
Eric Patton
email: epatton@nrcan.gc.ca
Sent: Tuesday, February 06, 2007 4:58 AM
To: Patton, Eric
fill holes
is created
this temporary
an alternate interpolation technique might be nice.
Hamish
suggest.
see-
M. Neteler. SRTM and VMAP0 data in OGR and GRASS. GRASS Newsletter,
3:2-6, June 2005. ISSN 1614-8746.
Hamish
