hellik
March 12, 2009, 9:38pm
1
hi,
i test a little bit the examples in
http://skagit.meas.ncsu.edu/~helena/grasswork/grassbookdat07/ncexternal/grasstestrast.txt
on grass64 from osgeo4w on a Win Vista 32 box.
I copy simply the command from the file above in the command line of the wx-gui
first example:
# find developed areas close to lakes
r.buffer lakes out=lakes_buff dist=60,120,240,500 --o
d.rast lakes_buff
r.mapcalc "developed_lake=if(landuse96_28m==1 || landuse96_28m==2, lakes_buff, null())"
d.rast developed_lake
d.vect streets_wake co=grey
d.rast -o lakes
following error message for the r.mapcalc-command:
(Thu Mar 12 22:32:47 2009)
syntax error, unexpected $end, expecting '='
Parse error
(Thu Mar 12 22:32:48 2009) Command finished (0 sec)
second example:
r.mapcalc "streets_travtime=1./streets_speed"
r.info streets_travtime
(Thu Mar 12 22:34:39 2009)
Parse error
(Thu Mar 12 22:34:39 2009) Command finished (0 sec)
best regards
helli
_______________________________________________________________________
DSL zum Nulltarif + 20 Euro Extraprämie bei Online-Bestellung über die
DSL Freundschaftswerbung! http://dsl.web.de/?ac=OM.AD.AD008K15279B7069a
On Thu, Mar 12, 2009 at 10:38 PM, Helmut Kudrnovsky <hellik@web.de> wrote:
hi,
first example:
d.rast lakes_buff
d.rast -o lakes
Parse error
I get the same on Linux. Apparently something in the GUI
is eating some characters of the formula.
I have opened a ticket for this:
http://trac.osgeo.org/grass/ticket/528
second example:
Parse error
best regards
helli
grass-user mailing list
grass-user@lists.osgeo.org
2009/3/13 Markus Neteler <neteler@osgeo.org>:
Parse error
try without quotation marks, e.g.
r.mapcalc developed_lake = if(landuse96_28m==1 || landuse96_28m==2,
lakes_buff, null())
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
On Fri, Mar 13, 2009 at 9:00 AM, Martin Landa <landa.martin@gmail.com> wrote:
Parse error
lakes_buff, null())
That works. Do you see a chance to also accept it quoted
as required for the true cmd line?
BTW: a subsequent
adds an entry to the manager but in the form
d.rast flags=developed_lake
which should be
d.rast map=developed_lake
