[GRASS-user] r.mapcalc questions
I have some questions concerning the use of r.mapcalc. I have a DEM made by r.surf.contour using the approach in the wiki (multiplying by 100000)[1]. Now when calculating back the original values I wonder about the values given by r.info. Calculation is done like so within the wxpython map calculator: r.mapcalc dtm_surf = dtm_surf.100k / 100000.0
Now r.info tells me:
Data Type: DCELL
which seems OK, but
Range of data: min = 130 max = 555
-> shouldn't these be float values after calculation?
and the comments
I definitely typed 100000.0! Where're my .0s? A quick visual verification with r.slope.aspect shows some terracing effects. That lets me suspect that the conversion to a DEM float raster failed somehow - but why?
I'm using the osgeo4w build on windows 7 64. GRASS GIS version is 6.4.1 (2011).
Many thanks
Frank
[1] http://grass.osgeo.org/wiki/Contour_lines_to_DEM
Frank BRONIEWSKI
METRICO s.à r.l.
géomètres
technologies d'information géographique
rue des Romains 36
L-5433 NIEDERDONVEN
tél.: +352 26 74 94 - 28
fax.: +352 26 74 94 99
http://www.metrico.lu
Data Type: DCELL
which seems OK, but
and the comments
For DCELL, r.info uses %.15g for the range, while r.mapcalc uses %.8g
for floating-point constants in the history. The "%g" format specifier
omits trailing zeros, and omits the decimal point if nothing follows
it.
The alternatives are "%f", which uses a fixed number of decimal
places, "%e" which always uses scientific (exponential) notation, or
"%#g", which always includes the decimal point and trailing zeros. All
of these have their drawbacks.
Would would be nice would be like the existing behaviour but always
retaining the decimal point and at least one digit, but there isn't
any easy way to get that.
A quick visual
but why?
Note that r.surf.contour works in floating-point and generates DCELL
output, so the multiplication and subsequent division should be
unnecessary.
Hi Glynn,
thanks for your response. So it's only a matter of string/number formatting with r.info? That's good to hear. I feared already the worst - sort of :slight_smile:
r.surf.contour uses floating point only in the latest version of GRASS, doesn't it? I read it too late in the wiki and my calculation was already half through, so I stuck with the "old method", but for newer calculations it's good to know that the workaround isn't necessary anymore.
Frank
Am 09.06.2011 08:58, schrieb Glynn Clements:
Data Type: DCELL
which seems OK, but
and the comments
it.
A quick visual
but why?
unnecessary.
Frank BRONIEWSKI
METRICO s.à r.l.
géomètres
rue des Romains 36
L-5433 NIEDERDONVEN
Yes.
doesn't it?
Yes. 6.4.0 uses CELL, 6.4.1 uses DCELL.
