[GRASS-user] r.mapcalc r.mapcalculator question
Hi, I am a new user to GRASS and have run into a problem while processing
rasters
I have 2 raster files (TIFFs) which I have loaded with GRASS in QGIS 1.0.2
Kore. The rasters contain values of 0 and 1 and represent 2 time steps. What
I wanted to do is either a simple addition of the 2 rasters or apply an OR
operator between them. For this I used the r.mapcalc and r.mapcalculator
tool. However, the cell size of the resulting raster is increased from 250m
to 2500m which leads to loss of fine scale information.
Does anyone know why this is happening and what I could do to maintain the
fine scale information?
Thank you
View this message in context: http://osgeo-org.1803224.n2.nabble.com/r-mapcalc-r-mapcalculator-question-tp5181949p5181949.html
Am Dienstag, den 15.06.2010, 06:39 -0700 schrieb varunvarma:
rasters
Thank you
Hi however,
please check the actual resolution with g.region -p. Is the result
res=2500? If so, set region with g.region -ap res=250 or with g.region
rast=inputrasterfile. You can controll it again with g.region -p. After
this settings run r.mapcalc again.
Manfred
rasters
Thank you
Hi however,
Manfred
In addition, to do the same thing within QGIS, you can use the "Edit current region" button on the GRASS toolbar. Just enter the value you need in the N-S resolution and E-W text boxes.
Another note: I might suggest you upgrade to a newer version of QGIS. Version 1.4 (and soon to be released 1.5) have many improvements and bug fixes.
Regards
grass-user mailing list
grass-user@lists.osgeo.org
This mail was received via Mail-SeCure System.
Micha Silver
http://www.surfaces.co.il/
Arava Development Co. +972-52-3665918
processing
rasters
1.0.2
What
OR
250m
the
Thank you
Hi however,
Manfred
fixes.
Regards
Micha Silver
Thank you all for your replies. I ran g.region to set the cell size (res) in
GRASS 6.4.0 and then used r.mapcalc to do an addition between the rasters
and it worked perfectly.
Just to understand the solution better, is there a reason why the cell size
was changed when an addition was performed on the rasters OR was it that the
cell size was changed when rasters were imported into GRASS?
Thank you,
Varun
View this message in context: http://osgeo-org.1803224.n2.nabble.com/r-mapcalc-r-mapcalculator-question-tp5181949p5185436.html
Am Mittwoch, den 16.06.2010, 01:10 -0700 schrieb varunvarma:
>>> processing
>>> rasters
>>> 1.0.2
>>> What
>>> OR
>>> 250m
>>> the
>>> Thank you
>> Hi however,
>> Regards,
>> Manfred
> fixes.
> Regards
>> _______________________________________________
> Micha Silver
Thank you,
Varun
Hi Varun,
I do'nt know, at which time the resolution changed (maybe it's the
default-region of your location?: g.region -dp). But raster operations
within GRASS are using the actual region settings and the new map would
be created with this settings, independent of the input raster maps. So
it's possible to generate raster maps with a new (higher or lower)
resolution and also maps clipped to a part of the input maps (to sphere
of interest) to save disc space, or memory capacity.
So before working with rastermaps it would be usefull to controll the
region settings.
Best regards,
Manfred
