[GRASS-user] r.mapcalc.tiled and mapset
Hello,
When I use r.mapcalc.tiled, all the mapsets become available from the working mapset.
example : r.mapcalc.tiled expression=“test=1” process=8
Is there any reason ?
I’m using grass 7.8
Thank you for your help.
Frank
That is probably a bug in GridModule, please open an issue,
Thanks, Anna
On Fri, Aug 19, 2022, 12:45 PM Frank David <frank.david@geophom.fr> wrote:
Hello,
I’m using grass 7.8
Frank
grass-user mailing list
grass-user@lists.osgeo.org
