[GRASS-user] r.massmov
_ I’m a rookie Grass user,
_ i have a problem in executing the r.massmov addon
_ after installing r.massmov through the graphical user interface (Menu - Settings - Addons Extension - Install),
when i try to execute ​the module i get this error message:
ScriptError
Unable to fetch interface description for command
‘r.massmov’.
Details: C:\Program Files (x86)\GRASS GIS
7.0.0svn\extrabin\python.exe: can’t open file ‘r.massmov’:
[Errno 2] No such file or directory​
_ I’ve never faced such kind of problem with Grass
_ Any suggestions are appreciated.
On Wed, Jan 14, 2015 at 1:39 PM, DEBERNARDI DANILO
<d.debernardi4@studenti.uninsubria.it> wrote:
_ I'm a rookie Grass user,
   when i try to execute the module i get this error message:
ScriptError
'r.massmov'.
7.0.0svn\extrabin\python.exe: can't open file 'r.massmov':
We have recently made heavy updates in the release branch. The Addons
are compiled against the current release branch, so that you need a
recent GRASS GIS 7 installation to remain compliant.
Later today the first release candidate (RC1) will be published, you
may try to install it as soon as available (a few days max) and then
install the addon.
Danilo,
could you tell us something more about your issue?
  • Are you using windows or linux?
  • Which GRASS version?
Maxi
Il giorno Wed Jan 14 2015 at 4:03:55 PM Markus Neteler <neteler@osgeo.org> ha scritto:
ScriptError
‘r.massmov’.
install the addon.
grass-user mailing list
grass-user@lists.osgeo.org
Hi Maxi
Danilo,
- Are you using windows or linux?
- Which GRASS version?
Maxi
I've tested also for Danilo.
It's a winGRASS issue. Some tests a few days ago with trunk.
it seems r.massmov.exe is built ok in winGRASS.
(compilation log:
http://wingrass.fsv.cvut.cz/grass71/addons/grass-7.1.svn/logs/r.massmov.log)
unfortunately it shows no reaction if you call it from the winGRASS-windows
command line or from wxGUI-command line; thus the autogenerated GUI of
r.massmov doesn't come up:
ScriptError
'r.massmov'.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/r-massmov-tp5181466p5183450.html
It means that there’s something to fix in the module? Or is a grass issue?
Thanks
Maxi
Il giorno ven 23 gen 2015 20:47 Helmut Kudrnovsky <hellik@web.de> ha scritto:
Hi Maxi
Danilo,
Maxi
I’ve tested also for Danilo.
It’s a winGRASS issue. Some tests a few days ago with trunk.
(compilation log:
r.massmov doesn’t come up:
ScriptError
‘r.massmov’.
best regards
Helmut
It means that there's something to fix in the module? Or is a grass issue?
tested here again:
GRASS Version: 7.1.svn
GRASS SVN revision: 64291
Build date: 2015-01-24
Build platform: i686-pc-mingw32
GDAL: 1.11.1
PROJ.4: 4.8.0
GEOS: 3.4.2
SQLite: 3.7.17
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
as r.massmov doesn't show any (re)action, it's hard to say; but I assume a
fix in r.massmov is needed.
a quick test with different debug levels:
g.gisenv set=DEBUG=3
g.gisenv set=DEBUG=5
C:\>r.massmov
C:\>
C:\>r.massmov --help
C:\>
C:\>r.massmov --ui
C:\>
if you try to invoke the module, unfortunately nothing happens: no error
message, no debug message, ...
maybe something with parallelization in windows?
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/r-massmov-tp5181466p5183520.html
I think that the quickest solution for this problem could be to change my pc platform or use a virtual platform (virtual box)
Could it be ?
What platform does support the r.massmov addon without error or interface problem?
Thanks, for the patience
________________________________________
Da: grass-user-bounces@lists.osgeo.org <grass-user-bounces@lists.osgeo.org> per conto di Helmut Kudrnovsky <hellik@web.de>
Inviato: sabato 24 gennaio 2015 15.17
A: grass-user@lists.osgeo.org
Oggetto: Re: [GRASS-user] r.massmov
tested here again:
GDAL: 1.11.1
PROJ.4: 4.8.0
GEOS: 3.4.2
SQLite: 3.7.17
Python: 2.7.4
wxPython: 2.8.12.1
C:\>r.massmov
C:\>
C:\>
C:\>r.massmov --ui
C:\>
best regards
Helmut
Danilo,
While developing we used Ubuntu and it was grass 7.0
Maxi
Il giorno mer 28 gen 2015 15:42 DEBERNARDI DANILO <d.debernardi4@studenti.uninsubria.it> ha scritto:
Could it be ?
tested here again:
GDAL: 1.11.1
PROJ.4: 4.8.0
GEOS: 3.4.2
SQLite: 3.7.17
Python: 2.7.4
wxPython: 2.8.12.1
as r.massmov doesn’t show any (re)action, it’s hard to say; but I assume a
C:>r.massmov
C:>
C:>r.massmov --help
C:>
C:>r.massmov --ui
C:>
message, no debug message, …
best regards
Helmut
