[GRASS-user] r.out.gdal bug? problems with createopt
Hi List,
I am trying to export a floating point raster into a tiff, BUT without writing
a GeoHeader (no GeoTiff!).
( I want to do this rather unusual thing, because the PCI Geomatics Software
has Problems with the Gauss Kruger Projection. It misinterprets a good
looking GeoTiff and writes only garbage in the GeoHeader of its output. But
if one feeds it just coordinates they line up perfectly.)
r.out.gdal [...] createopt="TFW=YES,PROFILE=BASELINE"
writes always a GeoHeader!
According to the GDAL documentation (http://www.gdal.org/frmt_gtiff.html) it
should not write any Geo-Stuff, if given the option PROFILE=BASELINE.
I then tested the scripted version
r.out.gdal.sh [...] createopt="TFW=YES,PROFILE=BASELINE"
and luckily it behaves and writes a tif without GeoHeader.
cheers,
  robert
Hi Robert,
it seems to be the same bug as it was found and fixed in v.out.ogr
some days ago by Martin.
I debugged a bit and found that the second part
"PROFILE=BASELINE" isn't passed. It gets lost in
main.c, line 554.
v.out.ogr's main.c (line 249 etc) has a working solution
but my try to port it to r.out.gdal failed (no idea why, should be
rather easy - but it segfaults for me).
So - we are close to a solution :slight_smile:
Robert Nuske wrote:
Hi List,
writing
Software
But
it
cheers,
  robert
grassuser mailing list
grassuser@grass.itc.it
View this message in context: http://www.nabble.com/r.out.gdal-bug--problems-with-createopt-tf4504650.html#a12847602
Moin Markus,
thanks for looking into my problem.
main.c, line 554.
I am not sure this is the only problem.
r.out.gdal [...] createopt="PROFILE=BASELINE"
doesn't work either
cheers,
  robert
Robert Nuske wrote:
> Hi List,
> writing
> Software
> But
> it
> cheers,
> robert
Markus Neteler wrote:
Hi Robert,
main.c, line 554.
What about moving this multi-option code to
G_store_multi() or something like this?
Modules with multi-option parameters are
- r.out.ogr
- v.out.ogr
- v.transform (new column parameter)
- maybe others
View this message in context: http://www.nabble.com/r.out.gdal-bug--problems-with-createopt-tf4504650.html#a12855513
