Hello all,
I’m having a problem with my r.out.gdal python code. This is the code (run from python shell in Grass7)
grass.run_command(‘r.outgdal’, input=items,
output='G:/Lokaverkefni/blettagreining/tifs/items[:-10]
Bestu kveðjur,
Adam Hoffritz
Adam Hoffritz wrote:
Hello all,
I'm having a problem with my r.out.gdal python code. This is the code (run
grass.run_command('r.outgdal', input=items,
I have no idea about working under windows and how to define paths. But, the "." is missing from your r.out.gdal command above (in case you copy-pasted).
Nikos
Hello all,
you copy-pasted).
As well, the r.out.gdal command accepts a single input or group which it will export. Given you need to export many "items", as the part "input=items" in your command above implies, the way to do it, should likely be to loop over a list of items.
You might want to post a bigger part of your code.
Nikos
