Hello Peter,
i have checked this issue.
The behavior of r.out.vtk is correct.
An input must be provided, this is not optional.
To change this, you have to apply this little patch:
--- parameters.c (Revision 37861)
+++ parameters.c (Arbeitskopie)
@@ -29,6 +29,7 @@
void set_params()
param.input = G_define_standard_option(G_OPT_R_INPUTS);
+ param.input->required = NO;
If you use the rgb and the input parameter (which is the default),
then you have to choose which data has should be displayed in your visualization software. By default, the input scalars are the "active"
scalar array in the vtk output file.
e.g:
In paraview 3.x select the display tab and choose "Color by" to switch from input scalars to rgb scalars.
Best regards
Soeren
-------- Original-Nachricht --------
Datum: Wed, 17 Jun 2009 15:18:23 +0200
Von: peter.loewe@gmx.de
An: grass-user@lists.osgeo.org
Betreff: [GRASS-user] r.out.vtk RGB / input issue
hi,
i am using v.out.vtk on grass6.3 on suse.
trying to export 2.5d rgb-maps to paraview using r.out.vtk always ends up
with an error message:
According to the module's manual it should be possible to export a RGBmap
+ dem by using the parameters
rgbmaps=redmap,bluemap,greenmap elevation=my_dem output=result.vtk
However, the module reports that the INPUT parameter has to be provided.
trying
input=rgbmap rgbmaps=redmap,bluemap,greenmap elevation=my_dem
output=result.vtk
results in the same as
input=rgbmap elevation=my_dem output=result.vtk
In both cases "result.vtk" is displayed with interpolated false colors.
How can a RGB composite created in GRASS properly be transferred and
displayed in Paraview ?
Peter
Dr. Peter Löwe
<peter.loewe@gmx.de>
GMX FreeDSL Komplettanschluss mit DSL 6.000 Flatrate und Telefonanschluss
für nur 17,95 Euro/mtl.!* http://portal.gmx.net/de/go/dsl02
grass-user mailing list
GRATIS für alle GMX-Mitglieder: Die maxdome Movie-FLAT!
Jetzt freischalten unter http://portal.gmx.net/de/go/maxdome01
