[GRASS-user] r.out.xyz: Output error
Hi Folks
Getting a problem with output in Grass 7.0.svn on Windows Vista SP2.
Here’s the dump:
(Sat Mar 30 17:34:34 2013)
r.out.xyz input=elev_ned_30m@PERMANENT output=D:_SDB\GIS_DataBase\Grass_Demo\Demo_locations\nc_spm_08\PERMANENT\elev_ned_30m_xyz2
‘output’ is not recognized as an internal or external command, operable program or batch file.
(Sat Mar 30 17:34:35 2013) Command finished (0 sec)
Managed to get the same command to work in Grass 6.4.2.
I believe this is a ‘basic’ feature that is unlikely to have been changed.
Has it not been implemented yet, or should I be sticking with 6.4.2?
Thanks
Stephen
On Sat, Mar 30, 2013 at 6:41 PM, Stephen Brearley
output=D:\_SDB\GIS_DataBase\Grass\_Demo\Demo_locations\nc_spm_08\PERMANENT\elev_ned_30m_xyz2
  'output' is not recognized as an internal or external command, operable
To me it looks as if there is a linebreak before the
output parameter. How do you call r.out.xyz - in a
scripts?
Right, the output parameter is the same
http://grass.osgeo.org/grass70/manuals/r.out.xyz.html
Changed parameters are listed here:
http://trac.osgeo.org/grass/wiki/Grass7/NewFeatures#Rastermodulechanges
Please let us know how you execute above command.
Apparently not from the GUI.
Marcus
See what you mean. No, the breaks are just the way I copied it from the
Command Console, as you can tell from the split of 'PERMA' and 'NENT'.
Should be (approx same as in your book):
r.out.xyz input=elev_ned_30m@PERMANENT >
lev_ned_30m_xyz2
  Stephen
-----Original Message-----
From: neteler.osgeo@gmail.com [mailto:neteler.osgeo@gmail.com] On Behalf Of
Markus Neteler
Sent: 30 March 2013 18:09
To: Stephen Brearley
Cc: GRASS user list
Subject: Re: [GRASS-user] r.out.xyz: Output error
To me it looks as if there is a linebreak before the output parameter. How
do you call r.out.xyz - in a scripts?
I believe this is a 'basic' feature that is unlikely to have been changed.
scripts?
tested with
GRASS version: 7.0.svn
GRASS SVN Revision: 55573
Build Date: 2013-02-30
GIS Library Revision: 52468 (2012-07-27)
GDAL/OGR: 1.9.2
PROJ.4: 4.8.0
GEOS: 3.3.6dev
SQLite: 3.7.10
Python: 2.7.2
wxPython: 2.8.12.1
Platform: Windows-Vista-6.0.6002-SP2 (OSGeo4W)
g.gisenv set=DEBUG=3
r.out.xyz --verbose input=elevation@PERMANENT output=J:\wd\routxyz\test1.txt
D2/3: filename =
C:\OSGeo4W\apps\grass\grass-7.0.svn\scripts\r.out.xyz.py
D2/3: G_file_name(): path = J:\gisdata/nc_spm_08/g7
path issue?
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/r-out-xyz-Output-error-tp5043808p5043819.html
D2/3: filename =
but very interesting...if the separator is given manually instead the
default one, r.out.xyz works:
r.out.xyz input=elevation@PERMANENT output=J:\wd\routxyz\test2.csv
separator=,
(Sat Mar 30 22:26:32 2013) Command finished (3 sec)
r.out.xyz input=elevation@PERMANENT output=J:\wd\routxyz\test3.csv
separator=;
(Sat Mar 30 22:28:00 2013) Command finished (2 sec)
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/r-out-xyz-Output-error-tp5043808p5043820.html
if the separator is given manually instead the default one, r.out.xyz works:
it seems given Default: | breaks the script, because also manually given |
stopps the script...
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/r-out-xyz-Output-error-tp5043808p5043821.html
