I've run r.param.scale multiple times to extract the various terrain
parameters from both 10m and 25m elevation maps. I set the region (and
resolution) to that of the input elevation map. All maps but the tangential
(planar) curvature map are properly rendered. This one comes out a solid
color. I don't see what I'm doing incorrectly on this one map.
tangential
solid
Suggestions appreciated.
Rich
It's possible there are outliers in your raster map that are skewing the
color table; what is the result of r.info -r? Check to see the range of
the raster makes sense.
Eric,
That's not the situation here: no outliers. I successfully ran this at 5
and 10m resolutions, and once at 25m resolution. The region was incorrect in
this last case and after properly setting the region I could no longer
produce the multicolored map I did before.
I'm not using that map since I _must_ get this report done and found a
different module (r.resamp.rst) that also generates tangential curves.
