Hello grass (ab)users!
I am using r.patch to merge 200 1 degree, 3 seconds resolution srtm's
(1-2 Mb each). After 24 hours of real time and 20 hours of Xeon
processor time I have 39% completed! My guess that this task shouldn't
take so long. Is r.patch a wrong tool to do this thing? Or is it a
bug? I am using grass-6.3.cvs.
Boris
check region extents and resolution ... can you send the output from
g.region -p ?
since I was trying to preserve resolution of original srtms.
Boris
PS Sorry Dylan
> Thanks,
> Boris
g.region -p ?
Boris
That is pretty big, but not impossibly big. Have you considered something like
gdal_merge.py for merging the files outside of GRASS ?
cheers,
Dylan
PS Sorry Dylan
> > Thanks,
> > Boris
> g.region -p ?
> Dylan
> Dylan Beaudette
> Soil Resource Laboratory
> http://casoilresource.lawr.ucdavis.edu/
> University of California at Davis
> 530.754.7341
Yes, though I couldn't figure out how to make gdal_merge output NULLs
instead of 0s (and what formats support NULLs?).
But anyway, you think that this is normal performance?
> Now, when you asking...
> Now it is this:
> projection: 3 (Latitude-Longitude)
> zone: 0
> datum: wgs84
> ellipsoid: wgs84
> north: 48:50:24.701676N
> south: 34:38:56.353164N
> west: 45:57:00.735336E
> east: 55:00:56.276712E
> nsres: 0:01:00.033312
> ewres: 0:00:59.991804
> rows: 851
> cols: 544
> cells: 462944
> But I believe that at the time I started r.patch it was this:
> zone: 0
> datum: wgs84
> ellipsoid: wgs84
> north: 46N
> south: 35N
> west: 35E
> east: 55E
> nsres: 0:00:03
> ewres: 0:00:03
> rows: 13200
> cols: 24000
> cells: 316800000
> Boris
cheers,
Dylan
> PS Sorry Dylan
> > > Thanks,
> > > Boris
> > g.region -p ?
> > Dylan
> > Dylan Beaudette
> > 530.754.7341
Dylan:
g.region -p ?
Boris:
rows: 13200
cols: 24000
cells: 316800000
Dylan:
something like gdal_merge.py for merging the files outside of GRASS ?
splitting that into four or eight smaller tiles would make it more manageable,
but as Dylan says that isn't impossibly big, perhaps even on the high side
of common. For really huge regions (> 50000^2) you might start thinking about
using 64bit processors and if GRASS and the OS were compiled with large file
support.
Given the number of maps and size of the region, I'm not surprised it
could take x*y*maps times longer than normal.
Boris:
hint 1: use g.region with multiple maps to set the region to the outer
bounds of all maps. For you with so many maps that could take a while,
so probably maps at the four corners would be enough.
g.region rast=map1,map2,map3,map4
hint 2: a low number of columns can be more important to speed than low
number of rows when doing things like displaying maps.
suggestion: wait 48 hours for it to finish then see if it is too big
to work with before deciding to split it up into smaller tiles.
Also it could be a lot faster to make 4 or 8 smaller tiles then r.patch
those together in a second pass. (ie reduce the module's search time
through known empty space)
Hamish
____________________________________________________________________________________
Never miss a thing. Make Yahoo your home page. http://www.yahoo.com/r/hs
Well, you assuming that NULL=0, but the sole reason for having NULL
layer in grass is that those values are not identical.
Boris
On Nov 16, 2007 5:55 PM, Charles Ehlschlaeger
r.mapcalc can easily convert your 0s into NULLS with the expression:
newmap = if(map == 0, null(), map)
r.mapcalc will solve most raster problems. GRASS users are advised to know
that program inside and out.
Sincerely, chuck
Chuck Ehlschlaeger, Associate Professor of Geography
Western Illinois University
215 Tillman Hall, 1 University Circle, Macomb, IL 61455
cre111@wiu.edu, phone: 309-298-1841, fax: 309-298-3003
-----Original Message-----
[mailto:grass-user-bounces@lists.osgeo.org] On Behalf Of Boris Avdeev
Sent: Friday, November 16, 2007 1:11 PM
To: dylan.beaudette@gmail.com
Cc: grass-user@lists.osgeo.org
Subject: Re: [GRASS-user] r.patch for stitching rasters?
> > Now it is this:
> > zone: 0
> > datum: wgs84
> > ellipsoid: wgs84
> > rows: 851
> > cols: 544
> > cells: 462944
> > zone: 0
> > datum: wgs84
> > ellipsoid: wgs84
> > north: 46N
> > south: 35N
> > west: 35E
> > east: 55E
> > nsres: 0:00:03
> > ewres: 0:00:03
> > rows: 13200
> > cols: 24000
> > cells: 316800000
> > Boris
like
> cheers,
> Dylan
> > PS Sorry Dylan
srtm's
shouldn't
> > > > Thanks,
> > > > Boris
> > > g.region -p ?
> > > Dylan
> > > Dylan Beaudette
> > > 530.754.7341
> Dylan Beaudette
> 530.754.7341
grass-user mailing list
grass-user@lists.osgeo.org http://lists.osgeo.org/mailman/listinfo/grass-user
No virus found in this incoming message.
Checked by AVG Free Edition.
Version: 7.5.503 / Virus Database: 269.15.33/1133 - Release Date: 11/15/2007
8:57 PM
No virus found in this outgoing message.
8:57 PM
another way is:
r.null map=yourmap setnull=0
agreed.
true, the data is lost when NULL is mixed with 0 in the first place, not when
changing 0->NULL.
Hamish
It does, but what formats support actual null layers? Of course I
might be able to find an unused rgb value and use it instead of NULL.
But what do you do if you don't have one?
Boris
