On Apr 15, 2009, at 12:46 AM, <grass-user-request@lists.osgeo.org> <grass-user-request@lists.osgeo.org> wrote:
Renae,
On Wed, Apr 15, 2009 at 7:16 AM, Renae Mackas <rmackas@sfu.ca> wrote:
Hello GRASS users-
I am trying to mosaic colourcomposites from LANDSAT images. A few weeks ago, I had luck doing this using r.patch with the -z flag such as below:
r.patch -z input=020.020.2000.055_rgb,021.020.2000.014_rgb,021.021.2000.142_rgb,022.020.2000.005_rgb output=mosaic
When I try doing this now however, r.patch does not seem to be working. In the output window, it shows a red cirle with an “X” in it next to the command, but does not print any error message below. I have tried patching even just the original rasters (rather than the rgb composites), and continue to get the same results.
Since the initial (successful) attempts with r.patch, I have extended the boundaries of the region I am working with and imported rasters from other locations. All of the image rasters are currently within the region boundaries though. Is there any reason why the changes I have made would have changed how r.patch functions? Any suggestions of how to get it working again?
r.patch (like almost all rast commands) respect the current region.
You need to first set the current region to all raster maps of interest,
then run r.patch:
g.region rast=020.020.2000.055_rgb,021.020.2000.014_rgb,021.021.2000.142_rgb,022.020.2000.005_rgb
-p
r.patch …
Hope this helps
You don’t say which GRASS version you are running and which platform you are using. Recently, we’ve run into the problem that random modules like r.patch do not work or work intermittently in Windows Vista using the OSGEO4W installer of GRASS 6.4RC3. A new binary installer for GRASS 6.4RC4 hopefully solves this problem.
Michael
> wrote:
Renae,
Hello GRASS users-
such as below:
working. In the output window, it shows a red cirle with an "X" in
results.
interest,
then run r.patch:
-p
r.patch ...
Hope this helps
You don't say which GRASS version you are running and which platform
you are using. Recently, we've run into the problem that random
Michael
grass-user mailing list
grass-user@lists.osgeo.org
Hi Michael-
I was using GRASS 6.3.0 on windows vista. Being that the current region was
set to the rasters and I still was having problems, I suspect that I may
have just been having temproary problems with r.patch. I will try updating
my version of GRASS and see if that helps.
Renae
View this message in context: http://n2.nabble.com/r.patch-not-working-tp2637005p2666902.html
