[GRASS-user] r.proj ERRO:Error seeking on segment file
Dear R Gurus,
I have an Albers project within Grass, and anoter in LatLong WGS84.
I want to import the Albers data within the LatLong WGS84 mapset.
But when I try r.proj (see below) I get ERRO:Error seeking on segment file
Any tip are welcome
Miltinho - mcr@rc.unesp.br
GRASS 6.4> r.proj --o input=MAREMA_fundoOK_binary_dila0600m_clump_mata_limpa_A
reaHA dbase="K:\HDprata_chatinho\MataAtlantica_gradAltitudinal\SDB_grass_MataA
tlantica_Altitudinal" mapset=PERMANENT location=newLocation --verbose
Input Projection Parameters: +proj=aea +lat_1=-5 +lat_2=-42
+lat_0=-32 +lon_0=-60 +x_0=0 +y_0=0 +no_defs +a=6378160 +rf=298.25
+towgs84=-60.0,-2.0,-41.0
Input Unit Factor: 1
Output Projection Parameters: +proj=longlat +no_defs +a=6378137
+rf=298.257223563 +towgs84=0.000,0.000,0.000
Output Unit Factor: 1
Input:
Cols: 50750 (54010)
Rows: 62835 (67152)
North: 2874331.656575 (2874331.656575)
South: -267418.343425 (-483268.343425)
West: 199083.566117 (36083.566117)
East: 2736583.566117 (2736583.566117)
EW-res: 50.000000
NS-res: 50.000000
Output:
Cols: 2783 (2783)
Rows: 3082 (3082)
North: -6.979567 (-6.979567)
South: -32.662917 (-32.662917)
West: -57.787937 (-57.787937)
East: -34.596239 (-34.596239)
EW-res: 0.008333
NS-res: 0.008333
Allocating memory and reading input map...
100%
Projecting...
Any tip are welcome
Input:
Cols: 50750 (54010)
Rows: 62835 (67152)
50750 * 62835 cells corresponds to a temporary file size of ~12 GB,
which requires large file support (LFS). I don't think that this works
on Windows at present, in which case you'll need to down-sample the
input file first.
(Raster maps are normally compressed, so the actual input file could
be under the 2GiB limit, but the temporary file required by r.proj
isn't compressed, as it needs random access).
Hi Glynn,
Thanks for the reply. I will resample the largest one.
cheers
miltinho
2012/12/9, Glynn Clements <glynn@gclements.plus.com>:
file
Any tip are welcome
Input:
Cols: 50750 (54010)
Rows: 62835 (67152)
input file first.
Laboratório de Ecologia Espacial e Conservação - LEEC
Depto de Ecologia - UNESP - Rio Claro
Av. 24A, 1515- Bela Vista
13506-900 Rio Claro, SP, Brasil
Fone: +55 19 3526-9647 (office) 19 3526-9680 (lab)
Cel: 19 9853-3220 / 19 9853-5430
Depto Ecologia http://www.rc.unesp.br/ib/ecologia/
PG ECO & BIODIV http://www.rc.unesp.br/ib/ecologia/posbiodiversidade/index.php
CV http://buscatextual.cnpq.br/buscatextual/visualizacv.do?id=K4792988H6&mostrarNroCitacoesISI=true&mostrarNroCitacoesScopus=true
Google citations http://scholar.google.com/citations?user=OWX_2eAAAAAJ
