[GRASS-user] r.proj ERROR
I want to re-project DEM data from a lambert-location into ETRS89/utm zone
33N
I did that many times before but now I get the following message:
r.proj location=MGI2wgs84_Austria_Lambert mapset=PERMANENT
input=dhm_10m_ogd_austria output=dhm_10m_ogd_dachstein_NEU method=bilinear
resolution=10
ERROR: Unable to open element file <> for <WIND@dachstein>
(Sat Jan 11 14:24:16 2020) Befehl ausgeführt (0 Sek)
The WIND file is ok. When I open it there are the correct region settings.
Whats wrong?
thx!
Nik
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
On Sat, Jan 11, 2020 at 2:28 PM nik <n.hafner@carto.at> wrote:
33N
resolution=10
Whats wrong?
We need to know GRASS GIS version and operating system...
Best
nik wrote
33N
resolution=10
ERROR: Unable to open element file <> for &lt;WIND@dachstein&gt;
Whats wrong?
thx!
Nik
which GRASS version and operating system are you using?
testing here with:
System Info
GRASS version: 7.8.2
Code revision: 3900fb114
Build date: 2019-12-11
Build platform: x86_64-w64-mingw32
GDAL: 3.0.2
PROJ: 6.2.1
GEOS: 3.8.0
SQLite: 3.29.0
Python: 3.7.0
wxPython: 4.0.7
Platform: Windows-10-10.0.18362-SP0 (OSGeo4W)
and tried here with a raster of the Dachstein region :wink:
g.proj -p
-PROJ_INFO-------------------------------------------------
name : MGI / Austria Lambert
datum : hermannskogel
ellps : bessel
proj : lcc
lat_0 : 47.5
lon_0 : 13.3333333333333
lat_1 : 49
lat_2 : 46
x_0 : 400000
y_0 : 400000
no_defs : defined
towgs84 : 577.326,90.129,463.919,5.1366,1.4742,5.2970,2.4232
-PROJ_EPSG-------------------------------------------------
epsg : 31287
-PROJ_UNITS------------------------------------------------
unit : meter
units : meters
meters : 1
g.region -p
projection: 99 (MGI / Austria Lambert)
zone: 0
datum: hermannskogel
ellipsoid: bessel
north: 413800
south: 391100
west: 407600
east: 441400
nsres: 100
ewres: 100
rows: 227
cols: 338
cells: 76726
g.proj -p
name : ETRS89 / UTM zone 33N
datum : etrs89
ellps : grs80
proj : utm
zone : 33
no_defs : defined
towgs84 : 0.000,0.000,0.000
epsg : 25833
unit : meter
units : meters
meters : 1
r.proj -g location=dachstein mapset=data input=raster2proj
WARNING: Found 2 possible transformations
Operation 1:
Description: axis order change (2D) + Inverse of Austria Lambert + MGI to
ETRS89 (1) + UTM zone 33N
Area of use: Austria
Accuracy within area of use: 1.5 m
PROJ string:
+proj=pipeline +step +inv +proj=lcc +lat_0=47.5 +lon_0=13.3333333333333
+lat_1=49 +lat_2=46 +x_0=400000 +y_0=400000 +ellps=bessel +step +proj=push
+v_3 +step +proj=cart +ellps=bessel +step +proj=helmert +x=577.326 +y=90.129
+z=463.919 +rx=5.137 +ry=1.474 +rz=5.297 +s=2.4232
+convention=position_vector +step +inv +proj=cart +ellps=GRS80 +step
+proj=pop +v_3 +step +proj=utm +zone=33 +ellps=GRS80
Operation 2:
ETRS89 (5) + UTM zone 33N
Accuracy within area of use: 0.15 m
PROJ string:
+proj=hgridshift +grids=AT_GIS_GRID.gsb +step +proj=utm +zone=33
+ellps=GRS80
See also output of:
projinfo -o PROJ -s "EPSG:31287" -t "EPSG:25833"
Please provide the appropriate PROJ string with the pipeline option
Selected pipeline:
Input map <raster2proj@data> in location <dachstein>:
n=5275655.1124836 s=5252234.92874731 w=381830.9328192 e=416111.44820006
rows=227 cols=338
g.region n=5275655.1124836 s=5252234.92874731 w=381830.9328192
e=416111.44820006 rows=227 cols=338
g.region -p
projection: 1 (UTM)
zone: 33
datum: etrs89
ellipsoid: grs80
north: 5275655.1124836
south: 5252234.92874731
west: 381830.9328192
east: 416111.44820006
nsres: 103.17261558
ewres: 101.42164314
rows: 227
cols: 338
cells: 76726
r.proj location=dachstein mapset=data input=raster2proj
output=rasterreprojected pipeline=+proj=pipeline +step +inv +proj=lcc
+lat_0=47.5 +lon_0=13.3333333333333 +lat_1=49 +lat_2=46 +x_0=400000
+y_0=400000 +ellps=bessel +step +proj=push +v_3 +step +proj=cart
+ellps=bessel +step +proj=helmert +x=577.326 +y=90.129 +z=463.919 +rx=5.137
+ry=1.474 +rz=5.297 +s=2.4232 +convention=position_vector +step +inv
+proj=cart +ellps=GRS80 +step +proj=pop +v_3 +step +proj=utm +zone=33
+ellps=GRS80
Input:
Cols: 338 (original: 338)
Rows: 227 (original: 227)
North: 413800.000000 (original: 413800.000000)
South: 391100.000000 (original: 391100.000000)
West: 407600.000000 (original: 407600.000000)
East: 441400.000000 (original: 441400.000000)
EW-res: 100.000000
NS-res: 100.000000
Output:
North: 5275655.112484 (original: 5275655.112484)
South: 5252234.928747 (original: 5252234.928747)
West: 381830.932819 (original: 381830.932819)
East: 416111.448200 (original: 416111.448200)
EW-res: 101.421643
NS-res: 103.172616
Allocating memory and reading input raster map...
Projecting...
r.proj complete.
it's using the new proj library version 6
C:\>projinfo -o PROJ -s "EPSG:31287" -t "EPSG:25833"
Candidate operations found: 2
Note: using '--spatial-test intersects' would bring more results (3)
Operation n┬░1:
unknown id, Inverse of Austria Lambert + MGI to ETRS89 (1) + UTM zone 33N,
1.5 m, Austria
PROJ string:
+proj=pipeline +step +proj=axisswap +order=2,1 +step +inv +proj=lcc
+ellps=GRS80
Operation n┬░2:
unknown id, Inverse of Austria Lambert + MGI to ETRS89 (5) + UTM zone 33N,
0.15 m, Austria, at least one grid missing
PROJ string:
+y_0=400000 +ellps=bessel +step +proj=hgridshift +grids=AT_GIS_GRID.gsb
Grid AT_GIS_GRID.gsb needed but not found on the system.
in the test I used the operation 1 as AT_GIS_GRID.gsb isn't installed here
in my system.
best regards
Helmut
PROJ string:
It has been added [1] and released only recently [2].
It may take some time to be shipped in the various distro/Windows packages.
[1] https://github.com/OSGeo/proj-datumgrid/issues/71
[2] https://github.com/OSGeo/proj-datumgrid/releases/tag/europe-1.5
Hi
I also use:
GRASS Version: 7.8.2
GDAL: 3.0.2
PROJ: 6.2.1
GEOS: 3.8.0
SQLite: 3.29.0
Python: 3.7.0
wxPython: 4.0.7
I still get this message:
resolution=10
and I tested it from an other location too but its the same problem:
r.proj location=ASTER_lat-long mapset=PERMANENT
input=DHM_SRTM30m_Aut-plus-Umgebung output=dhm_30m_ASTER_dachstein
method=bilinear resolution=30
What can be wrong?
Nik
nik wrote
Hi
I also use:
GDAL: 3.0.2
PROJ: 6.2.1
GEOS: 3.8.0
SQLite: 3.29.0
Python: 3.7.0
wxPython: 4.0.7
resolution=10
What can be wrong?
Nik
grass-user mailing list
grass-user@.osgeo
What does r.proj -g output? With PROJ: 6.2.1, a proj pipeline has to be
given in r.proj. it's not in your cmd
Can you report all steps with g.proj, g.region, r.proj in source and
target locations as I've done?
best regards
Helmut
best regards
Helmut
g.proj -p
name : Lambert Conformal Conic
proj : lcc
ellps : bessel
lat_1 : 49
lat_2 : 46
lat_0 : 47.5
lon_0 : 13.33333333333333
x_0 : 400000
y_0 : 400000
no_defs : defined
unit : metre
units : metres
meters : 1
g.region -p
projection: 99 (Lambert Conformal Conic)
zone: 0
ellipsoid: bessel
north: 576922.51207363
south: 273692.51207363
west: 106549.26720377
east: 694629.26720377
nsres: 10
ewres: 10
rows: 30323
cols: 58808
cells: 1783234984
g.proj -p
name : Universal Transverse Mercator
proj : utm
datum : etrs89
ellps : grs80
zone : 33
towgs84 : 0,0,0,0,0,0,0
no_defs : defined
unit : metre
units : metres
meters : 1
g.region -p
projection: 1 (UTM)
zone: 33
datum: etrs89
ellipsoid: grs80
north: 5286581.58847414
south: 5248335.67358037
west: 380870.53610518
east: 429633.13185005
nsres: 9.998932
ewres: 10.00053235
rows: 3825
cols: 4876
cells: 18650700
I downloaded and installed http://www.bev.gv.at/portal/page?_pageid=713,2157075&_dad=portal&_schema=PORTAL
r.proj -g location=MGI2wgs84_Austria_Lambert mapset=PERMANENT input=dhm_10m_ogd_austria output=dhm_10m_ogd_dachstein_NEU method=bilinear resolution=10 pipeline=+proj=pipeline +step +inv +proj=lcc +lat_0=47.5 +lon_0=13.3333333333333 +lat_1=49 +lat_2=46 +x_0=400000 +y_0=400000 +ellps=bessel +step +proj=hgridshift +grids=AT_GIS_GRID.gsb +step +proj=utm +zone=33 +ellps=GRS80
n=1.#INF s=5132938.26037436 w=78264.72048991 e=1.#INF rows=30323 cols=58808
Eingabekarte <dhm_10m_ogd_austria@PERMANENT> in Location <MGI2wgs84_Austria_Lambert>:
(Mon Jan 13 10:19:18 2020) Befehl ausgeführt (0 Sek)
But nothing happend!
And please tell me why do I have to give a pipeline in r.proj? I thought that would defined by the locations resp. regions.
thx!
best regards
Helmut
g.proj -p
proj : lcc
ellps : bessel
lat_1 : 49
lat_2 : 46
lat_0 : 47.5
x_0 : 400000
y_0 : 400000
no_defs : defined
unit : metre
units : metres
meters : 1
g.region -p
zone: 0
ellipsoid: bessel
nsres: 10
ewres: 10
rows: 30323
cols: 58808
cells: 1783234984
g.proj -p
proj : utm
datum : etrs89
ellps : grs80
zone : 33
no_defs : defined
unit : metre
units : metres
meters : 1
g.region -p
projection: 1 (UTM)
zone: 33
datum: etrs89
ellipsoid: grs80
nsres: 9.998932
ewres: 10.00053235
rows: 3825
cols: 4876
cells: 18650700
cols=58808
Eingabekarte &lt;dhm_10m_ogd_austria@PERMANENT&gt; in Location
thx!
for r.proj -g you don't need the pipeline, try just
see also example https://grass.osgeo.org/grass78/manuals/r.proj.html
# same calculation, but in a form which can be cut and pasted into a
g.region call
r.proj input=elevation location=ll_wgs84 mapset=user1 -g
the pipeline is needed later for the reprojection process.
best regards
Helmut
cols=58808
Nik, have you set the current region correctly?
for r.proj -g you don’t need the pipeline, try just
g.region call
A pipeline is not really needed, in case of several possible operations, PROJ should automagically select the best available operation. Note that also with r.proj -g coordinate transformation takes place.
Markus M
Am 13.01.2020 um 14:23 schrieb Markus Metz:
> g.region call
thx Markus and Helmut!
Yes that is what I would expect and what I´ve done many times before but since shortly I get this message:
resolution=10
I tested it from an other location too but it´s the same problem:
What does that mean?
the pojection and region settings of both input and output are als follows:
g.proj -p
proj : lcc
ellps : bessel
lat_1 : 49
lat_2 : 46
lat_0 : 47.5
x_0 : 400000
y_0 : 400000
no_defs : defined
unit : metre
units : metres
meters : 1
g.region -p
zone: 0
ellipsoid: bessel
nsres: 10
ewres: 10
rows: 30323
cols: 58808
cells: 1783234984
g.proj -p
proj : utm
datum : etrs89
ellps : grs80
zone : 33
no_defs : defined
unit : metre
units : metres
meters : 1
g.region -p
projection: 1 (UTM)
zone: 33
datum: etrs89
ellipsoid: grs80
nsres: 9.998932
ewres: 10.00053235
rows: 3825
cols: 4876
cells: 18650700
ERROR: Unable to open element file <> for WIND@dachstein
This is a bug in r.proj: the mapset dachstein does not exist in the source location, therefore also no WIND file in the mapset dachstein because this mapset does not exist. The new PR #286 https://github.com/OSGeo/grass/pull/286 fixes this bug, but it exposes another bug in r.import.
Markus M
g.proj -p
proj : lcc
ellps : bessel
lat_1 : 49
lat_2 : 46
lat_0 : 47.5
x_0 : 400000
y_0 : 400000
no_defs : defined
unit : metre
units : metres
meters : 1
g.region -p
zone: 0
ellipsoid: bessel
nsres: 10
ewres: 10
rows: 30323
cols: 58808
cells: 1783234984
g.proj -p
proj : utm
datum : etrs89
ellps : grs80
zone : 33
no_defs : defined
unit : metre
units : metres
meters : 1
g.region -p
projection: 1 (UTM)
zone: 33
datum: etrs89
ellipsoid: grs80
nsres: 9.998932
ewres: 10.00053235
rows: 3825
cols: 4876
cells: 18650700
grass-user@lists.osgeo.org
