On Fri, Mar 18, 2011 at 1:31 PM, TimNorwey <timmy_weyrer@live.at> wrote:
OK ... the locations are in there too.
Perfect, like this testing is easy.
I can download the file, without any problems.
But I will attach it here again and hope that you can download it:
http://osgeo-org.1803224.n2.nabble.com/file/n6184337/ReProjectWGS84toUTM15.zip
GRASS 6.4.1svn (utm15):~/grassdata > r.proj in=tif_test out=dem30_tif
location=reproj_tif_84 mapset=reproj_tif_84 method=bilinear
resolution=30
Input Projection Parameters: +proj=longlat +no_defs +a=6378137
+rf=298.257223563 +towgs84=0,0,0,0,0,0,0
Input Unit Factor: 1
Output Projection Parameters: +proj=utm +no_defs +zone=15 +a=6378137
+rf=298.257222101 +towgs84=0,0,0,0,0,0,0
Output Unit Factor: 1
Input:
Cols: 180 (180)
Rows: 180 (180)
North: 30.100000 (30.100000)
South: 30.050000 (30.050000)
West: -90.600000 (-90.600000)
East: -90.550000 (-90.550000)
EW-res: 0.000278
NS-res: 0.000278
Output:
Cols: 165 (166)
Rows: 188 (189)
North: 3332400.000000 (3332400.000000)
South: 3326760.000000 (3326730.000000)
West: 731280.000000 (731250.000000)
East: 736230.000000 (736230.000000)
EW-res: 30.000000
NS-res: 30.000000
Allocating memory and reading input map...
100%
Projecting...
100%
r.proj complete.
No problems here... the resulting map looks fine. My system:
uname -a
Linux north 2.6.33.7-desktop-2mnb #1 SMP Mon Sep 20 18:19:20 UTC 2010
x86_64 x86_64 x86_64 GNU/Linux
Someone on Mac needs to try.. Or Tim, you need to run it through
a debugger, see
http://grass.osgeo.org/wiki/GRASS_Debugging#Using_GDB
and post the full backtrace to a Trac ticket for analysis.
PS: I'll send the reprojected map to you.
