Hi Grass Users out there,
certainly something total easy, but is there a way to reclassify negative values with r.reclass?
fp: Data range is -0.2180119007825851440429688 to 0.1608885973691940307617188
> -0.2180119007825851440429688 thru 0.001 = 1 label
-0.718012 rounded up to 0
0.501000 rounded up to 0
Does r.reclass only work with integer or positive values? I couldn't find anything about that in the manual.
GRASS 6.0.1 (Yes, I know I am little late with updating...)
Only integer maps can be reclassed.
yes, it is the problem, map shall be multipied by for example 1000000 then reclasified
However, r.reclass is especially useful because it DOESN'T create a new map.
It just makes a new cats table for an existing raster map. This means that
it is sort of a 'virtual' map or map 'view'. It also means that it runs much
faster (important in interated scripts) and takes up very little space (also
good for iteration that creates multiple map 'views').
It would be nice if this could be done with FP maps too somehow, since FP
maps also have cats tables that affect how they are displayed.
Michael
Arizona State University
new map. It just makes a new cats table for an existing raster map.
This means that it is sort of a 'virtual' map or map 'view'. It also
means that it runs much faster (important in interated scripts) and
takes up very little space (also good for iteration that creates
I don't see any reason why FP maps shouldn't be able to be base maps for
a reclassification into integer categories (besides r.reclass lacks the
code to do this AFAIK).
since FP maps also have cats tables that affect how they are
displayed.
FCELL, DCELL (floating point) maps do have cats/ tables, but they are
typically empty*,**.
* you can add labels there for different values, e.g. for d.legend
** FCELL,DCELL lists number of cats as 255 (this shows up in r.info)
why?
Hi
I thing that in some situaltion reclass is the only solution and cannot be repaced with mapclac..
for example curvature map with values between -1 and 1 with most data like 0.0000345, when more than 10 new categories are needed (nested if () 10 times ??)
btw: there are in grass some more integer-output modules -for example d.histogram...
unfortunatly I'm not a C programmer...
Hamish napisał(a):
Michael Barton wrote:
R.mapcalc and r.recode both create new maps.
displayed.
why?
