[GRASS-user] r.region
If I have about 800 raster files in tiff format that are in the wrong projection. Is there a way to change their coordinate systems all at once. After examining r.region it seems to only want to change one raster at a time. Will I have to build a command in unix, in order to change these rasters projections?
Thanks
Aaron
The simplest way to reproject a bunch of tiff files into a new projection is to use gdalwarp in a loop. Something like,
for i in ls *.tif | awk 'BEGIN {FS="."} ; {print $1} '; do
gdalwarp s_srs epsg:26910 t_srs epsg:2766 $i.tif $i_spcs-CaliforniaZone1.tif
done
You’ll have to play with the syntax as I don’t use it very often but this example should transform all the tiff files in the local directory from epsg:26910 (NAD83 UTM10) to epsg:2766 (SPCS NAD83 California zone 1).
Mike
Thanks
Aaron
grassuser mailing list
grassuser@grass.itc.it
r.region is not for changing raster's projection. It only moves and
rescales it in space, by setting "the boundary definitions for a raster
map".
If you want to reproject, use r.proj instead.
As to multiple raster input - in shell you could use something like:
for i in `g.list rast mapset=some_mapset | grep
string_common_for_all_rasters_you_want_included`
do
r.some.command input=${i} output=${i}_suffix
done
Mind that g.list always prints a few extra lines of text at the top and
the bottom of it's output, which you have to watch out for when
grep'ping for a string. You can filter them out with:
g.list rast mapset=some_mapset | grep -v "files available in
mapset\|----------------------------------------------"
BTW - it would be really nice IMHO to have a "Print in shell script
style" option in g.list, ie. no extra text, one name per line.
Maciek
raster map".
for i in `g.list rast mapset=some_mapset | grep string_common_for_all_rasters_you_want_included`
do
done
and the bottom of it's output,
Use g.mlist.
for MAP in `g.mlist rast` ; do
  r.info -r $MAP
done
for i in `ls *.tif | [...]
beware that the max command line string may be 4096 chars, and 800 maps
could fill that. ("basename $file .tif" in the `command` part could help
conserve 4 chars per map)
back to the original question:
once.
As the input is TIFF, probably the easy way is to use GDAL tools,
specifically gdalwarp and/or gdal_translate to make a new GeoTIFF in the
target projection.
Hamish
Use g.mlist.
  r.info -r $MAP
done
Right. Thanks Hamish.
Maciek
