[GRASS-user] r.resamp.* and CPU usage
I am trying to resample a DEM using either r.resamp.rst or r.resamp bspline on a server where I share resources with my colleagues.
Both modules take almost 100% of the CPU (meaning all cores get busy). Can I somehow control/limit the number of cores GRASS modules are allowed to use?
Stefan
On Tue, Jun 14, 2016 at 12:12 PM, Blumentrath, Stefan
<Stefan.Blumentrath@nina.no> wrote:
When you use time, 100% of CPU means one core is fully used. Two fully
used cores would be reported by time as 200%. Both modules use only a
single core. lib/gmath used by r.resamp bspline might use more cores
if GRASS has been compiled with openmp, but for r.resamp.bspline you
would only see a marginal increase in CPU usage above 100%.
Can I
Only very few GRASS modules can use more than one core. For openmp,
you can control the number of cores with
setenv OMP_NUM_THREADS X
for pthread used with lib/gis
setenv WORKERS X
with X being the maximum number of allowed threads.
HTH,
Markus M
Stefan
grass-user mailing list
grass-user@lists.osgeo.org
Hi Markus,
Thanks for the reply.
When you use time, 100% of CPU means one core is fully used. Two fully used cores would be reported by time as 200%. Both modules use only a
single core.
I started r.reamp.bspline and r.resamp.rst once and saw equally many PIDs in htop than cores in the system and all cores got ~ 80% busy.
At the same time I got an email from a colleague asking me if I could spare some CPU for him as well, because his processes got significantly slowed down :wink:
lib/gmath used by r.resamp bspline might use more cores if GRASS has been compiled with openmp, but for r.resamp.bspline you would
I compiled GRASS 7.0 with OpenMP option, yes.
Only very few GRASS modules can use more than one core. For openmp, you can control the number of cores with
export OMP_NUM_THREADS=5 solved it for me on Ubuntu.
Thanks again!
Kind regards,
Stefan
