[GRASS-user] r.resamp.rst - ERROR: Input window changed while maps are open for read.
Dear all,
I'm trying to use r.resamp.rst in GRASS7, I would like to interpolate
a map from a resolution of 1m to a resolution of 0.25.
I'm working with the following region:
GRASS 7.0.svn (edi):~ > g.region -p
projection: 99 (Transverse Mercator)
zone: 0
datum: osgb36
ellipsoid: airy
north: 674050
south: 673911
west: 325025
east: 325233
nsres: 1
ewres: 1
rows: 139
cols: 208
cells: 28912
Now if I try to run the following command I got:
GRASS 7.0.svn (edi):~ > r.resamp.rst input=diff ew_res=0.25 nsres=0.25
elev=diff_overl3_ten40 overlap=3 tension=40.
ERROR: Input window changed while maps are open for read. Map name <diff>
If I change the region to the resolution 0.25 I still got the same error:
GRASS 7.0.svn (edi):~ > g.region res=0.25 -p
zone: 0
datum: osgb36
ellipsoid: airy
north: 674050
south: 673911
west: 325025
east: 325233
nsres: 0.25
ewres: 0.25
rows: 556
cols: 832
cells: 462592
ERROR: Input map resolution differs from current region resolution!
the map diff is a FCELL map
GRASS 7.0.svn (edi):~ > r.info diff -g
north=680000
south=650000
east=340000
west=310000
nsres=1
ewres=1
rows=30000
cols=30000
cells=900000000
datatype=FCELL
What did I do wrong?
Any hints?
Pietro
Map name <diff>
Any hints?
you didn't do anything wrong, the module has not been fully ported to grass 7 yet. try it in GRASS 6.
Hamish
On Mon, May 6, 2013 at 12:49 PM, Pietro <peter.zamb@gmail.com> wrote:
Dear all,
Note also the module mentioned below.
Re r.resamp.rst usage:
On Thu, May 22, 2008 at 4:02 PM, Paul Kelly wrote:
On Thu, 22 May 2008, Hamish wrote:
Thanks for the answer - I am in the process of trying it out. But:
When I try to use r.resamp.rst, I get the error message "Input map
resolution differs from current region resolution!". I thought that
r.resamp.rst is doing exactly that - changing the resolution?
As far as I know it works "the wrong way round", i.e. different from the
other resampling modules - you actually run it with the resolution set to
that of the original map (g.region rast=mapname), and set the desired new
resolution using command-line options.
I'm afraid that this is still the case.
However, like this it should work for you.
Note also this module:
http://grass.osgeo.org/grass70/manuals/r.resamp.interp.html
r.resamp.interp - Resamples raster map layers to a finer grid using
interpolation.
@devs: the best might be to add the RST method to r.resamp.interp...
Dear all,
the issue is still there. I get the same error message. Using the stable
version of GRASS (6.4) is not an option for me since I am working with very
large files (>2GB) for which this module returns the error described here
<http://trac.osgeo.org/grass/ticket/1786&gt; .
Any suggestions?
Many thanks,
Bert
View this message in context: http://osgeo-org.1560.x6.nabble.com/r-resamp-rst-ERROR-Input-window-changed-while-maps-are-open-for-read-tp5051545p5129311.html
Bert,
On Sun, Mar 16, 2014 at 6:39 PM, bwus <b3rt.wu@gmail.com> wrote:
Dear all,
The ticket reports on r.resamp.rst in GRASS 6. We cannot fix it there
easily since many libraries are involved (see ticket).
Does the problem also exist in GRASS 7 for you?
You can install it in parallel to GRASS 6, see
http://grass.osgeo.org/download/software/linux/#grass70
In 6.x, the tempfile code in the RST library is limited to 2 GiB
(ticket #1786).
In 7.x, the RST library isn't working because it hasn't been updated
for the new raster window handling (r40772 etc) (ticket #1718).
