Dear list,
using the r.resamp.rst to resample the resolution of my DGM-raster gave me the following result:
"change region temporarily to desired resolution...
change again to the original-region...
Percent complete:
dnorm in ressegm after grid before out2= 1329.287217
dnorm in mainc after grid before out1= 1329.287217
dnorm in mainc after grid before out2= 1329.287217
Temporarily changing the region to desired resolution...
Changing the region back to initial...
r.resamp.rst completed. "
I look forward to get some possibilites about how to get my desired resolution.
Regards
Chris
_________________________________________________________________
Express yourself instantly with MSN Messenger! Download today it's FREE!
http://messenger.msn.click-url.com/go/onm00200471ave/direct/01/
christian Brandt schrieb:
Dear list,
Percent complete:
dnorm in ressegm after grid before out2= 1329.287217 dnorm in mainc after grid before out1= 1329.287217 dnorm in mainc after grid before out2= 1329.287217
Regards
Chris
Christian,
Could you tell us the command-line you used?
you can also use r.resample and change the desired resolution manually with g.region (see man r.resample)
cheers
Philipp
PS: You aren't the boyfriend of Ulle... are you???
