Hello,
Let me introduce myself: I'm french and new to the GRASS Universe
I'm really amazed by all its possibilities and hope I will have the
knowledge take the most of them..
I've got some problems with resampling an image.
Initially, I wanted to vectorize an image
After having imported it, I tried to thin it through the r.thin command.
But the image produced being too big, it caused errors on my computer.
To solve my problem, I decided to reduce my location resolution: res=2, then
that of my raster with r.resample...
The problem is that my resampled raster output is empty.
When typing r.info raster.resampled, I get:
r.info raster.resampled2
| Layer: raster.resampled Date: Tue Feb 16 15:10:35 2010
| Mapset: PERMANENT |
| DataBase: D:\GRASS Database
| Title: ( raster )
| Timestamp: none
| Type of Map: raster Number of Categories: 0
| Data Type: CELL
| Rows: 500
| Columns: 500
| Total Cells: 250000
| Projection: Lambert Conformal Conic
| N: 6133000 S: 6132000 Res: 2
| E: 1235000 W: 1234000 Res: 2
| Range of data: min = NULL max = NULL
| Data Description:
| generated by r.in.gdal
| Comments:
| r.in.gdal input="C:/tests/GRASS/rasterToVect/BDP_08_1234_6134_010_L9\
| 3.tif" output="raster"
(Mon Feb 22 14:28:09 2010) Command finished (0 sec)
What is strange is the null range of data...
The r.info for my raster input, not resampled is:
r.info raster6133_2
| Layer: raster6133_2 Date: Fri Feb 19 16:35:13 2010
| Mapset: PERMANENT |
| Title: ( raster6133_2 )
| Timestamp: none
| Type of Map: raster Number of Categories: 1
| Data Type: CELL
| Rows: 10000
| Columns: 10000
| Total Cells: 100000000
| N: 6133000 S: 6132000 Res: 0.1
| E: 1235000 W: 1234000 Res: 0.1
| Range of data: min = 0 max = 1
| Data Description:
| Comments:
| r.in.gdal input="C:/tests/vectorisation/BDParcellaire/BDP_08_1234_61\
| 33_010_L93.tif" output="raster6133_2"
Why is the range of data null?
How to solve that problem?
Thanks in advance!
Mat'
View this message in context: http://n2.nabble.com/r-resample-null-values-for-min-and-max-range-of-data-values-tp4631171p4631171.html
