Hello,
I try to rescale a rastermap with category values ranging from 1 to 16.
I want to rescale them by dividing the values by the maximum value, like
1 --> 1/16, 10-->10/16 and 16 --> 1). I tried to do that with the r.rescale tool with setting the output range to 0,1 like:
r.rescale input=input output=output to=0.0,1.0
but it I don't get float values as a results, only 0 and 1 as integers. Does r.rescale handle floats and how do I have to rescale it? Or is there any other simple way to divide the single raster values by the maximum value and get a float value as result?
thank you
/johannes
GMX DSL Doppel-Flat ab 19,99 Euro/mtl.! Jetzt mit
gratis Handy-Flat! http://portal.gmx.net/de/go/dsl
johannes,
Have you considered r.mapcalc?
Rich
No. r.rescale is a front-end to r.reclass, which only handles
integers.
r.recode provides similar functionality to r.reclass for
floating-point data (but it creates an entirely new map; reclass maps
only support integer data).
r.mapcalc "output = input / 16.0"
Am 23.03.2011 um 05:29 schrieb Glynn Clements:
1 → 1/16, 10–>10/16 and 16 → 1). I tried to do that with the r.rescale tool with setting the output range to 0,1 like:
but it I don’t get float values as a results, only 0 and 1 as
integers.
I looked at it but with r.code, I’ve to provide the input data range values as
fixed values (at least one) rather then saying use all values from min to max
as it is possible in rescale…
r.mapcalc “output = input / 16.0”
I think r.mapcalc is probably the best solution, but as I don’t know the maximum
value in every case (I’ve to process several maps), I wanted to automatize.
Probably I’ve to write a script to read the max value and parse it to the mapcalc function.
My problem: First, I don’t know how to do that, Second there is this python-script issue
on my mac (see other thread)…
grass-user mailing list
grass-user@lists.osgeo.org
I think r.mapcalc is probably the best solution, but as I don't know the maximum
value in every case (I've to process several maps), I wanted to automatize.
Probably I've to write a script to read the max value and parse it to the mapcalc function.
My problem: First, I don't know how to do that, Second there is this python-script issue
on my mac (see other thread)...
"r.info -r ..." will output the minimum and maximum values.
For a shell script, you can use e.g.:
eval `r.info -r $inmap`
r.mapcalc "$outmap = float($inmap) / $max"
For a Python script, you can use grass.script.raster_info(), e.g.:
import grass.script as grass
max = grass.raster_info(inmap)['max']
grass.mapcalc("$outmap = $inmap / $max",
inmap = inmap, outmap = outmap, max = max)
On Thu, Mar 24, 2011 at 6:07 PM, Glynn Clements
eval \`r\.info \-r $inmap\`
r\.mapcalc "$outmap = float\($inmap\) / $max"
Added here:
http://grass.osgeo.org/wiki/GRASS_and_Shell#Using_output_from_GRASS_modules_in_the_script
import grass\.script as grass
max = grass\.raster\_info\(inmap\)\['max'\]
grass\.mapcalc\("$outmap = $inmap / $max",
inmap = inmap, outmap = outmap, max = max\)
Added here:
http://grass.osgeo.org/wiki/GRASS_and_Python#Using_output_from_GRASS_modules_in_the_script
