Message: 1
Date: Tue, 19 May 2009 16:15:57 -0600
Subject: [GRASS-user] r.series g.mlist unhappy together
To: grass-user@lists.osgeo.org
Message-ID: <12A3B1D9-B843-4ED8-BD26-8D0754F7A8AA@gmail.com>
Content-Type: text/plain; charset="us-ascii"
I am trying to use g.mlist to gather files to use with r.series.
r.series input="`g.mlist pat='*1987*pdds' sep=,`" output=test1987dd0
method=sum
When i run this i get:
method=sum
Sorry, <pat> is not a valid parameter
Sorry, <sep> is not a valid parameter
When i run g.mlist alone i get the list of files that i expect.
I have successfully run r.series alone by manually selecting the files
I want to sum.
If only I could get r.series and g.mlist to be happy!
I am using GRASS6.4.ORC4 on Mac OS X V.10.5.6
If anyone has an idea why this is happening I would greatly appreciate
it!
Saewan,
I am chiming in late, I realise, but you could structure it this way:
for i in `g.mlist rast pattern="*1987*ppds`; do
r.series input=$i output=test1987dd0 method=sum --overwrite;
done
Note that the g.mlist command is surrounded by "tick marks", not single quotes.
This structure works fine for me in either OSX or Linux terminals for other
activities. The downside is that instead of running all the input maps at once,
it will do the processing accumulatively, which would be slow if you have lots
of input rasters.
RC
Hi Richard,
Thank you for the tip. Now that i am working off of the terminal I can start exploring different ways to improve my work flow.
Saewan
On 20-May-09, at 4:10 PM, Richard Chirgwin wrote:
Message: 1
method=sum
method=sum
I want to sum.
it!
Saewan,
done
of input rasters.
RC
grass-user mailing list
