[GRASS-user] r.series g.mlist unhappy together
Martin:
important here is that you are using "command prompt" from wxGUI which
behaves in different way from shell. The prompt in wxGUI is planned to
be rewritten, see [1].
[1] http://grass.osgeo.org/wiki/WxGUI#Layer_Manager
with the current code (ie for 6.4.0) is there any hope to provide at least
basic quoting, so e.g. this can work:
v.db.select roads "where=label ~ 'highway'"
or '\ ' for quoted space, or {} instead of "".
(I'm not familiar with python's quoting req's)
thanks,
Hamish
