Again - thanks for all the help so far, it is much appreciated.
Laurent - I ran the read2_command and it returned the following:
File “”, line 254, in run_nodebug
File “C:\Users\ggrewcock\Dropbox\PythonScripts\gmt\grass-interface-v2.py”, line 85, in
grass.read2_command(‘r.shade’, shade=‘hillshade_output_python’,color=‘dem_slope’, output=‘shaded_raster_hillshade_map’, brighten=‘25’, overwrite=True)
AttributeError: ‘module’ object has no attribute ‘read2_command’
Moritz - I have managed to get r.shade to run in the UI by creating the module object however, when I run through the script I get a parsing error. Is this because python env variables are all ‘buried’ within the ArcGIS folder?
File “”, line 3, in
File “C:\OSGEO4~1\apps\grass\grass-7.0.3\etc\python\grass\pygrass\modules\interface\module.py”, line 471, in init
tree = fromstring(self.xml)
File “C:\Python27\ArcGIS10.4\Lib\xml\etree\ElementTree.py”, line 1301, in XML
return parser.close()
File “C:\Python27\ArcGIS10.4\Lib\xml\etree\ElementTree.py”, line 1654, in close
self._raiseerror(v)
File “C:\Python27\ArcGIS10.4\Lib\xml\etree\ElementTree.py”, line 1506, in _raiseerror
raise err
xml.etree.ElementTree.ParseError: no element found: line 1, column 0
Gareth
On Mon, May 23, 2016 at 6:26 PM, Moritz Lennert <mlennert@club.worldonline.be> wrote:
On 23/05/16 15:01, Gareth Grewcock wrote:
Hi Stefan - thanks for getting back to me.
I had tried that before but still got issues, this time returning:
‘NameError: name ‘r’ is not defined’
/r.shade(shade=aspect, color=elevation, output=elevation_aspect_shaded)/
/Traceback (most recent call last)
/ File “”, line 1, in /
/NameError: name ‘r’ is not defined/
Any ideas what might be causing that?
If you are using pygrass, you have to create the r.shade module object before using it. See [1].
If you are not using pygrass, please give us more information about what happens in your script before the call that fails.
Moritz
[1] https://grass.osgeo.org/grass70/manuals/libpython/pygrass_modules.html
