[GRASS-user] r.shaded.relief question
   I successfully cut out of the source DEM a small area matching that of the
project watershed. When I ran r.slope.aspect the output maps looked as they
should.
   Feeling irrationally exuberant that I might be able to quickly move on to
hydrological modeling, I just tried running r.shaded.relief on the same
raster DEM map used for the slopes, aspects, and curvatures. No joy. the
relief map looks like the earlier slope and aspect ones: vertical bands of
horizontal static.
   This is all within the latest weekly checkout of 6.4. What might I be
missing if all I specify to r.shaded.relief is the input and output map name
and leave the other options at their defaults?
Rich
horizontal static.
   Got this fixed: it was incorrect region resolution.
   Now I have a question about the results. The source DEM has the highest
area in the southeast corner and the main stream drains northwest to the
confluence with a large river. The shaded relief map, however, does not
reflect this topography. Both maps have a resolution of 10m.
   On the shaded relief map, the drainage basin head appears as flat as the
confluence area.
   Why might I see results like this? Do I need to interpolate the source DEM
to a finer resolution before running r.shade.relief?
Suggestions needed,
Rich
confluence area.
   Fixed this, too. r.shaded.relief needed the zmult set higher than 1. '5'
does very nicely.
Rich
