When I run r.sim.water, I get the following output “GRASS_INFO_WARNING(18240,1): Infiltration exceeds the rainfall rate everywhere! No overland flow.”
If I understand all the inputs correctly, one inputs the rainfall excess (runoff) and the rainfall infiltration, and the intensity (rate) is calculated by the module by the equation (Rainfall Excess = Rainfall Intensity - Infiltration rate).
How can my infiltration exceed the rainfall rate if rainfall rate = Infiltration + runoff?
"GRASS_INFO_WARNING(18240,1): Infiltration exceeds the rainfall rate
everywhere! No overland flow."
General hint:
Please note that r.sim.water has been recently modified in GRASS 6.3-CVS
to support more intuitive units. In case that you use 6.3-CVS, please
check if this (still) matches your input parameters. The manual has
been updated.
General hint:
been updated.
r.sim.water checks if the "maximum" infiltration rate is greater than
the "maximum" rainfall excess rate and, if so, gives the warning
"Infiltration exceeds the rainfall rate 'everywhere'!", which is not
true.
The r.sim.water manual says:
user can provide a runoff infiltration rate map infil in [mm/hr] that
control the rate of infiltration for **the already flowing water**,
effectively reducing the flow depth and discharge.
It seems to me that the infiltration rates implicitly given by the rain
map (rainfall-infiltration) and by the infil map are different. If they
are the same, your "rainfall rate = infiltration + runoff" holds true.
As I understand it, however, infil is not the same as infiltration in
this equation.
Huidae Cho
When I run r.sim.water, I get the following output "GRASS_INFO_WARNING(18240,1): Infiltration exceeds the rainfall rate everywhere! No overland flow."
Mark
The 6.3 manual is much more clear about this than the 6.2 manual. The infil map is the rate at which the ground absorbs water once the soil is saturated (surface water already flowing), not when it is dry. Also the mm/hr units was a big help. the 6.3 manual says that x,y,z can be in feet, as well as the dx,dy (ft/ft), but the rain and infil in mm/hr.
Thanks! Looks like I might have some results by tomorrow.
r.sim.water checks if the “maximum” infiltration rate is greater than
the “maximum” rainfall excess rate and, if so, gives the warning
“Infiltration exceeds the rainfall rate ‘everywhere’!”, which is not
true.
control the rate of infiltration for the already flowing water,
are the same, your “rainfall rate = infiltration + runoff” holds true.
this equation.
Huidae Cho
Mark
Mark
Good - please keep us posted! And don't hesitate to hack the
HTML documentation directly if things should be clarified -
we can then merge it.
