GRASS has changed a lot in past years. Now it's better than ever
To catch-up with GRASS progress, You need to do some RTFM'ing. http://grass.itc.it/grass63/manuals/html63_user/r.stats.html:
"Note that the user has only the option of printing out cell
statistics in terms of cell counts and/or area totals. Users wishing
to use different units than are available here should use the GRASS
program r.report."
Have a nice return,
Maris.
2007/10/10, Gordon Keith <gordon.keith@csiro.au>:
I've recently returned to grass after a while of not needing to do that sort
of analysis and found the analysis I previously did no longer works.
I downloaded and installed the latest stable version of grass and processes
similar to those I have run over different data in grass5.
r.stats -a for a Latitude-Longitude location gave the area in square meters in
grass5, but appears to the area is square degrees in grass6.
Is there a way of getting area in square meters from r.stats in grass6?
Regards
Gordon
Gordon Keith
Programmer/Data Analyst
Marine Acoustics
CSIRO Marine and Atmospheric Research http://www.cmar.csiro.au
By the turn of this century, we will live in a paperless society
-- Roger Smith, chairman of General Motors, 1986
