[GRASS-user] r.stream.basins vector outlets help (Jens Hegg)
Ok, I figured out how to make it work for the vector file. I was including both the flow direction and the stream network along with the vector file. It turns out that only the direction and vector outlets files are needed and then it runs perfectly. The manual examples really should be updated to include a vector points example.
I do still have one problem that someone might be able to help with. Many of the points I use for outlets are just downstream of one another so it creates watersheds that are just small slivers between points. Is it possible for it to create overlapping watersheds as you move down the stream, or do I need to go back and do this manually?
Jens
On Feb 9, 2015, at 6:08 PM, grass-user-request@lists.osgeo.org wrote:
Send grass-user mailing list submissions to
  grass-user@lists.osgeo.org
To subscribe or unsubscribe via the World Wide Web, visit
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
  grass-user-owner@lists.osgeo.org
When replying, please edit your Subject line so it is more specific
than "Re: Contents of grass-user digest..."
Today's Topics:
  1. Import/Export of ESRI Arc ascii grids (Thomas Adams)
  2. GRASS GIS 7.0.0 RC2 released (Markus Neteler)
  3. Re: Import/Export of ESRI Arc ascii grids (Markus Neteler)
  4. Re: Import/Export of ESRI Arc ascii grids
     (C?sar Augusto Ram?rez Franco)
  5. Re: v.generalize: does it take forever? (F?bio Dias)
  6. r.stream.basins vector outlets help (Jens Hegg)
Message: 1
Date: Mon, 9 Feb 2015 13:12:45 -0700
To: "grass-user@lists.osgeo.org" <grass-user@lists.osgeo.org>
Subject: [GRASS-user] Import/Export of ESRI Arc ascii grids
Message-ID:
  <CAGxgkWjdCo1pJNT1PAfSarUCfm5foaudLiLXcLGZC2UteNV39g@mail.gmail.com>
Content-Type: text/plain; charset="utf-8"
All,
I'm probably missing the obvious, but has support for import/export of ESRI
Arc ascii grids been dropped in GRASS 7.x? I can not find r.in.arc and
r.out.arc in either the documentation or in GRASS itself. If it has been
dropped, why? I know I can use GRASS 6.4.x?
Tom
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150209/38dbcb14/attachment-0001.html&gt;
Message: 2
Date: Mon, 9 Feb 2015 21:18:21 +0100
To: GRASS developers list <grass-dev@lists.osgeo.org>, GRASS user list
Cc: OSGeo-discuss <discuss@lists.osgeo.org>, GRASS-announce list
  <grass-announce@lists.osgeo.org>
Subject: [GRASS-user] GRASS GIS 7.0.0 RC2 released
Message-ID:
  <CALFmHhtmwEEXCLkLeJkjJKX6JciC1Q0dwApkDqUkvaFjaeUK7Q@mail.gmail.com>
Content-Type: text/plain; charset=UTF-8
We are pleased to announce the second release candidate of the
upcoming stable GRASS GIS 7.0.0 version.
Between 7.0.0RC1 and the current 7.0.0RC2 about 100 updates have been applied.
MOST IMPORTANT CHANGES in RC2:
* Updated Welcome and splash screens
* 3D raster: terminology cleanup (raster3D -> 3D raster) in commands and manual
* g.proj: generate PROJ_EPSG file (contains EPSG code) when location is given
* r.cost, r.walk: change percent_memory to memory (in MB)
* v.extract: index added
* v.in.ogr: do not use old projection for area calculations in new projection
* v.generalize: self-intersection fix
* v.patch, v.reclass, v.overlay, v.vect.stats: accommodate SQLite
* vector lib: numerical stability fixes for centroid calculation
* vector lib: more robust topology engine
* some simple mononchrome color tables added
* wxGUI/nviz: 3D rendering fixes
* several translations updated
Related updates in QGIS:
* Further updates in QGIS Processing - GRASS GIS 7 interface submitted to QGIS
Related updates in OSGeo-Live:
* GRASS GIS 7.0.0 RC2 planned to be shipped with the new OSGeo-Live 8.5
See also our detailed announcement:
http://trac.osgeo.org/grass/wiki/Release/7.0.0RC-News
http://trac.osgeo.org/grass/wiki/Grass7/NewFeatures
DOWNLOAD
Binaries:
http://grass.osgeo.org/download/software/#g70rcx
Source code:
http://grass.osgeo.org/grass70/source/grass-7.0.0RC2.tar.gz
http://grass.osgeo.org/grass70/source/grass-7.0.0RC2.md5sum
Changelog:
http://grass.osgeo.org/grass70/source/ChangeLog_7.0.0RC2.gz
Please test on "any" platform which is supported (GNU/Linux,
MS-Windows, Mac OSX, *BSD, ...).
The GRASS Development Team
Message: 3
Date: Mon, 9 Feb 2015 21:26:01 +0100
To: Thomas Adams <tea3rd@gmail.com>
Cc: "grass-user@lists.osgeo.org" <grass-user@lists.osgeo.org>
Subject: Re: [GRASS-user] Import/Export of ESRI Arc ascii grids
Message-ID:
  <CALFmHhsHKRZQ9ORmDqNEp1SWFK1VC3bWUHgyr58yfs7DKeZu=w@mail.gmail.com>
On Mon, Feb 9, 2015 at 9:12 PM, Thomas Adams <tea3rd@gmail.com> wrote:
All,
Of course not :slight_smile:
dropped, why?
Because r.in.gdal and r.out,gdal do the job nicely.
For an overview of changes, see
http://trac.osgeo.org/grass/wiki/Grass7/NewFeatures#Replacedandremovedmodules
Message: 4
Date: Mon, 9 Feb 2015 16:22:59 -0500
From: C?sar Augusto Ram?rez Franco <caesarivs@gmail.com>
Message-ID: <25DEB00C-3AF2-4FEF-8BB3-CF50BA7F829C@gmail.com>
Content-Type: text/plain; charset=utf-8
I think that functionality has been merged into r.in.gdal
Have you tried it?
C?sar
El 9/02/2015, a las 3:12 p.m., Thomas Adams <tea3rd@gmail.com> escribi?:
All,
I'm probably missing the obvious, but has support for import/export of ESRI Arc ascii grids been dropped in GRASS 7.x? I can not find r.in.arc and r.out.arc in either the documentation or in GRASS itself. If it has been dropped, why? I know I can use GRASS 6.4.x?
Tom
Message: 5
Date: Mon, 9 Feb 2015 19:52:41 -0200
To: Markus Metz <markus.metz.giswork@gmail.com>
Cc: GRASS user list <grass-user@lists.osgeo.org>
Subject: Re: [GRASS-user] v.generalize: does it take forever?
Message-ID:
  <CAFSZSaJF4Gb9uNwiyqnX5fH=GAcK_ie=0BsHOOGcCcxEDWNFfQ@mail.gmail.com>
Content-Type: text/plain; charset=ISO-8859-1
I switched to postgis for data storage and the v.generalize time went
down to 130ish minutes, all processes working in parallel.
I'm happy now :slight_smile: thanks you guys very much.
F?bio Augusto Salve Dias
ICMC - USP
http://sites.google.com/site/fabiodias/
On Tue, Jan 27, 2015 at 8:50 PM, F?bio Dias <fabio.dias@gmail.com> wrote:
I've kept an iotop, cumulative, running while the generalization run.
No disk IO involved, just a couple of postgre stats. I believe the OS
is keeping everything in RAM cache. I don't believe the disk is a
bottleneck either, it is a 10 disk raid of 15k rpm disks, it's really
fast.
I interrupted the processing, moved everything into postgres and
started over. I'm still loading the shapefiles (that I'm doing one at
a time), I'll start the 15 processes as soon as it is loaded. As soon
as that stabilizes, I'll report back.
On a related note, wouldn't it be interesting to always try to
simplify a line? As I understood the code, if the simplification fails
for any reason, the original line is used. Might be interesting to
have an option that makes the algorithm retry that line, with half the
threshold, for instance. It's kind of weird for me to see one side of
something really simplified while the other side really complicated :slight_smile:
F
ICMC - USP
On Tue, Jan 27, 2015 at 7:56 PM, Markus Metz
<markus.metz.giswork@gmail.com> wrote:
On Mon, Jan 26, 2015 at 3:54 PM, F?bio Dias <fabio.dias@gmail.com> wrote:
The machine has 128Gb of ram. Doesn't matter what I do, I can't make a
dent on it. Even with everything cached in ram (shp files, database,
the whole lot), there is still free memory.
OK, it's not RAM.
I'm asking about the database because the behavior I'm seeing on 'top'
looks like the one you get when mutexes are involved. The processes
don't go all to 100% processing at same time (and the machine has 64
processors, so no dent there either), except for the v.in.ogr.
The v.generailze processes should be at 100% while generalizing,
unless the disk can not keep up with multiple simultaneous IO
requests. The tables are copied only after the generalization finished
(100% reached).
What it
looks like is that something is locking each process and they are
taking turns. Considering how 'lite' the sqlite appears to be, and the
weird locking behavior that was mentioned in other threads (I'm not
getting the locked message here... I did, when I was running 2
parallel v.in.ogr), isn't it likely to be the culprit? Should I change
it to a more 'non-lite' system, like postgres for instance?
That could make sense when running multiple processes in parallel. An
alternative would be to create a separate mapset for each process and
at the end copy the results back to the main mapset.
Technically, it is not possible that the new v.generalize version in
trunk (G71) is slower than the old version as in relbr70 because the
new version updates only those parts of the topology that actually get
changed. The old version also updates components that do not get
changed, this is quite time-consuming.
I understand you like to go for the big nail immediately, but maybe it
is worth testing first on a smaller sample?
Markus M
F
ICMC - USP
On Mon, Jan 26, 2015 at 7:22 AM, Markus Metz
On Mon, Jan 26, 2015 at 9:30 AM, Markus Metz
On Sun, Jan 25, 2015 at 6:11 PM, F?bio Dias <fabio.dias@gmail.com> wrote:
Running r64249, with a couple of stuff in parallel using &. It seems
to be considerably slower.
Very strange. Are you using trunk or GRASS 7.0?
Here, v.generalize on a TerraClass tile is down from 25 minutes to 13 seconds.
More than 100h, no 1% printed. To be fair,
I'm not entirely sure I'll see it when it prints, 10 v.generalize
running (5 for each year) + 1 v.in.ogr for 2012. That v.in.ogr is
running for almost 100h too. I'm loading the shps directly, as advised
way, way back in this thread.
What exactly do you mean with "loading shps directly"? For
v.generalize, you should import them with v.in.ogr.
What about memory consumption on your system? With 10 v.generalize + 1
v.in.ogr on such a big dataset, quite a lot of memory would be used.
Markus M
AFAIK, no disk is been used, the whole thing is cached (after more
than 24h processing, cumulative iotop shows only a few mb
written/read). I'm no longer using a ramdisk for the grassdata dir.
However, it appears to be considerably slower, probably because of the
parallel running jobs.
My question then would be, considering the thread I saw about sqlite,
should I be using something else as backend? When it starts to make
sense to change it?
F
ICMC - USP
On Wed, Jan 14, 2015 at 1:06 PM, Markus Neteler <neteler@osgeo.org> wrote:
On Wed, Jan 14, 2015 at 3:54 PM, F?bio Dias <fabio.dias@gmail.com> wrote:
What would be the best way to do that in parallel? One mapset for each
year? Can I run multiple v.generalizes on the same input with
different outputs?
Yes sure.
My first thought was to run completely separated grass processes for
each simplification, but I didn't find a way to make it search
something different than .grass / .grass70 for the configuration
stuff....
Maybe take a look at this approach
http://grasswiki.osgeo.org/wiki/Parallel_GRASS_jobs#Grid_Engine
but even sending different v.generalize jobs to background (&) should
work if you have enough RAM.
markusN
Message: 6
Date: Mon, 9 Feb 2015 18:08:05 -0800
To: grass-user@lists.osgeo.org
Subject: [GRASS-user] r.stream.basins vector outlets help
Message-ID: <5C00976C-7B42-4AE9-AEC4-A5BD562847BF@gmail.com>
Content-Type: text/plain; charset="us-ascii"
I am trying to use r.stream.basins to delineate multiple watersheds upstream of water sampling points. From the manual page it appears that you can input a vector file with multiple stream outlet points under the command points= however I can't make that work. I get the error "ERROR: Only one outlet definition is allowed".
The manual states that the "Every point shall have his own unique category." which I assume is the case for a vector file of points but perhaps I'm missing something. I have edited the points to make sure that each point overlays the stream on the stream direction map. My stream and direction maps are both output from r.watershed.
Can anyone tell me what I'm doing wrong here? I'm using GRASS 7.0 on Mac OSX 10.7.5.
Jens Hegg
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150209/bd723225/attachment.html&gt;
End of grass-user Digest, Vol 106, Issue 18
Hei Jens,
If you want to have watersheds which overlap, you have to have them in different maps as neither raster nor vector data with topology (as in GRASS GIS) allow for overlapping areas.
That again means you would have to run r.stream.basins for your vector points individually, e.g. in a loop like this:
points=$(v.db.select -c map=mypoints column=cat)
for p in $points
do
  v.extract ...
  r.stream.basisns ...
done
Stefan
-----Original Message-----
From: grass-user-bounces@lists.osgeo.org [mailto:grass-user-bounces@lists.osgeo.org] On Behalf Of Jens Hegg
Sent: 10. februar 2015 05:32
Subject: Re: [GRASS-user] r.stream.basins vector outlets help (Jens Hegg)
Jens
Today's Topics:
Message: 1
Message-ID:
All,
Tom
-------------- next part -------------- An HTML attachment was
scrubbed...
URL:
cb14/attachment-0001.html>
Message: 2
Message-ID:
and manual
is given
projection
to QGIS
8.5
DOWNLOAD
Binaries:
Source code:
Changelog:
Message: 3
Message-ID:
All,
been dropped, why?
modules
Message: 4
Have you tried it?
C?sar
All,
Tom
Message: 5
Message-ID:
ICMC - USP
fast.
fails for any reason, the original line is used. Might be interesting
to have an option that makes the algorithm retry that line, with half
the threshold, for instance. It's kind of weird for me to see one
side of something really simplified while the other side really
F
ICMC - USP
make a dent on it. Even with everything cached in ram (shp files,
database, the whole lot), there is still free memory.
OK, it's not RAM.
64 processors, so no dent there either), except for the v.in.ogr.
finished (100% reached).
What it
the weird locking behavior that was mentioned in other threads (I'm
not getting the locked message here... I did, when I was running 2
change it to a more 'non-lite' system, like postgres for instance?
An alternative would be to create a separate mapset for each process
and at the end copy the results back to the main mapset.
get changed. The old version also updates components that do not get
it is worth testing first on a smaller sample?
Markus M
F
ICMC - USP
seems to be considerably slower.
More than 100h, no 1% printed. To be fair, I'm not entirely sure
I'll see it when it prints, 10 v.generalize running (5 for each
year) + 1 v.in.ogr for 2012. That v.in.ogr is running for almost
100h too. I'm loading the shps directly, as advised way, way
v.generalize + 1 v.in.ogr on such a big dataset, quite a lot of memory would be used.
Markus M
more than 24h processing, cumulative iotop shows only a few mb
of the parallel running jobs.
sqlite, should I be using something else as backend? When it
starts to make sense to change it?
F
ICMC - USP
for each year? Can I run multiple v.generalizes on the same
input with different outputs?
Yes sure.
processes for each simplification, but I didn't find a way to
make it search something different than .grass / .grass70 for
the configuration stuff....
should work if you have enough RAM.
markusN
Message: 6
Jens Hegg
scrubbed...
URL:
3225/attachment.html>
Sefan,
Thanks for the help. I'm still not getting it to run, but I am not at all familiar with anything beyond running basic commands on the command console, I've mostly just used the GUI. Should these be input into the command console or the Python shell? I've tried both, the console seems to not recognize most of it, the Python shell gives me lots of syntax errors (which seems like a good start, I just don't know Python at all).
Here is what I have:
points=$(v.db.select -c map=Fish_and_Water_PointsEPSG4140 column=cat))
for p in $points
do
  v.extract --overwrite input=Fish_and_Water_PointsEPSG4140 output=temp_point_map cat=(p) type=point
  r.stream.basins direction=HenrysDrainage@HenrysFork points=temp_point_map basins=Basin_(p)
done
The first error is a syntax error at the dollar sign in points=$(v.db.select...
Am I getting close? The idea is that temp_point_map gets overwritten at each loop so all that remains is the last one. I'm wanting to name each new basin by the category so I can go back and figure out it's attribute data.
Jens
On Feb 9, 2015, at 11:04 PM, Blumentrath, Stefan wrote:
Hei Jens,
for p in $points
do
  v.extract ...
done
Stefan
Jens
Today's Topics:
Hi Jens,
Sorry, my fault. I should have asked you about your platform first.
Assuming you are on Windows I guess python would be most suitable language for scripting. Unfortunately I am not that good at python, but I am sure others will fill in.
You might need something like:
points = grass.read_command("v.to.db", map='YOUR_VECTOR_POINTS", columns='', option='coor', separator=',', flags='p')
for p in points.splitlines():
  x=p.split(',')[2]
  y= p.split(',')[3]
  grass.run_comand('r.stream.basin', dirs=..., coors="%d,%d" % (x, y), ...)
Good luck!
Stefan
Sent: 10. februar 2015 21:22
To: Blumentrath, Stefan
Cc: grass-user@lists.osgeo.org
Sefan,
points=$(v.db.select -c map=Fish_and_Water_PointsEPSG4140 column=cat)) for p in $points do
  r.stream.basins direction=HenrysDrainage@HenrysFork points=temp_point_map basins=Basin_(p) done
Jens
Hei Jens,
points=$(v.db.select -c map=mypoints column=cat) for p in $points do
  v.extract ...
done
Stefan
Hegg)
Jens
Today's Topics:
1. Import/Export of ESRI Arc ascii grids (Thomas Adams) 2. GRASS
GIS 7.0.0 RC2 released (Markus Neteler) 3. Re: Import/Export of ESRI
Arc ascii grids (Markus Neteler) 4. Re: Import/Export of ESRI Arc
ascii grids
5. Re: v.generalize: does it take forever? (F?bio Dias) 6.
I'm on a Mac, if that makes any difference. I will try this and see how it goes.
Sent from my iPhone
On Feb 10, 2015, at 3:06 PM, "Blumentrath, Stefan" <Stefan.Blumentrath@nina.no> wrote:
Hi Jens,
   x=p.split(',')[2]
   y= p.split(',')[3]
Good luck!
Stefan
Sefan,
Jens
Hei Jens,
   v.extract ...
done
Stefan
Hegg)
Jens
Today's Topics:
ascii grids
The advantage with python is that it is (more or less) platform independent.
What I send you first was a UNIX shell script for bash.
That obviously does not work on all UNIX like systems (like Mac in your case).
It might work if you change your terminal / shell to "bash" (http://osxdaily.com/2012/03/21/change-shell-mac-os-x/).
But python is more future oriented, anyway. So if you manage to make run in Python, that would be a better start into the world of scripting than starting with shell scripts (and then moving to Python at some point later (what I will have to - or more precisely like to- do sooner or later)...
For more info see e.g.:
http://grasswiki.osgeo.org/wiki/GRASS_and_Python
http://grasswiki.osgeo.org/wiki/GRASS_Python_Scripting_Library
Stefan
Sent: 11. februar 2015 00:13
Sent from my iPhone
Hi Jens,
columns='', option='coor', separator=',', flags='p') for p in points.splitlines():
   x=p.split(',')[2]
   y= p.split(',')[3]
y), ...)
Good luck!
Stefan
Hegg)
Sefan,
Jens
Hei Jens,
   v.extract ...
done
Stefan
Hegg)
Jens
Today's Topics:
ESRI Arc ascii grids (Markus Neteler) 4. Re: Import/Export of ESRI
Arc ascii grids
