[GRASS-user] r.stream.extract error
I’m using the r.stream.extract grass command
r.stream.extract elevation=elv accumulation=upa threshold=0.5 depression=dep direction=dir stream_raster=stream memory=35000 --o --verbose
where the elv is raster of 142690 * 80490 = 11,485,118,100 cell
and I get this error
12.97% of data are kept in memory
Will need up to 293.52 GB (300563 MB) of disk space
Creating temporary files…
Loading input raster maps…
0…3…6…9…12…15…18…21…24…27…30…33…36…39…42…45…48…51…54…57…60…63…66…69…72…75…78…81…84…87…90…93…96…99…100
ERROR: Unable to load input raster map(s)
According to the help manual the memory=35000 should be set in according to the overall memory available. I set the HPC upper memory limit to 40G.
I try several combination of these parameters but i still get the same error.
If the r.stream.extract is based on r.watershed than the segmentation library should be able to handle a huge raster.
Anyone know how to over pass this limitation/error ?
Thank you
Best
Giuseppe Amatulli, Ph.D.
Research scientist at
Yale School of Forestry & Environmental Studies
Yale Center for Research Computing
Center for Science and Social Science Information
New Haven, 06511
Teaching: http://spatial-ecology.org
Work: https://environment.yale.edu/profile/giuseppe-amatulli/
On Mon, Oct 30, 2017 at 1:42 PM, Giuseppe Amatulli <giuseppe.amatulli@gmail.com> wrote:
This error is caused by integer overflow because not all variables necessary to support such large maps were 64 bit integer.
Fixed in trunk and relbr72 with r71620,1, and tested with a DEM with 172800 * 67200 = 11,612,160,000 cells: r.stream.extract finished successfully in 18 hours (not a HPC, a standard desktop maschine with 32 GB of RAM and a 750 GB SSD).
r.stream.extract is based on a version of r.watershed that did not support yet such huge raster maps, therefore support for such huge raster maps needed to be added to r.stream.extract separately.
Please use the latest GRASS 7.2 or GRASS 7.3 version from svn.
Markus M
Thank you
Best
New Haven, 06511
grass-user mailing list
grass-user@lists.osgeo.org
Thanks Markus!!
I will test and I will let you know how it works.
I have few more questions
  1. now how much is the upper limit matrix cell number that r.stream.extract can handle?
  2. is the r.stream.basins add-on subjects to the same limitation? In case would be possible to update also for r.stream.basins?
  3. is r.stream.extract support the use of multi-threaded through openMP? Would be difficult implement?
Best
Giuseppe
On 31 October 2017 at 15:54, Markus Metz <markus.metz.giswork@gmail.com> wrote:
Markus M
Thank you
Best
New Haven, 06511
New Haven, 06511
On Wed, Nov 1, 2017 at 7:15 PM, Giuseppe Amatulli <giuseppe.amatulli@gmail.com> wrote:
Thanks Markus!!
Your feedback is very helpful!
About 1.15e+18 cells.
Another limitation is the number of detected stream segments. This must not be larger than 2,147,483,647 streams, therefore you need to figure out a reasonable threshold with a smaller test region. A threshold of 0.5 is definitively too small, no matter how large or small the input is. Threshold should typically be larger than 1000, but is somewhat dependent on the resolution of the input. As a rule of thumb, with a coarser resolution, a smaller threshold might be suitable, with a higher resolution, the threshold should be larger. Testing different threshold values in a small subset of the full region can safe a lot of time.
  1. is the r.stream.basins add-on subjects to the same limitation? In case would be possible to update also for r.stream.basins?
The limitation in r.watershed and r.stream.extract comes from the search for drainage directions and flow accumulation. The other r.stream.* modules should support large input data, as long as the number of stream segments does not exceed 2,147,483,647.
  1. is r.stream.extract support the use of multi-threaded through openMP? Would be difficult implement?
In your case, only less than 13% of temporary data are kept in memory. Parallelization with openMP or similar will not help here, your CPU will run only at less than 20% with one thread anyway. The limit is disk I/O. You can make it faster by using more memory and/or using a faster disk storage device.
Markus M
Best
Giuseppe
Markus M
Thank you
Best
New Haven, 06511
New Haven, 06511
Thanks again!!
I’m working with a area-flowaccumulation so the 0.5 threshold means 0.5 km2, which is 90m * 90m * 60 cell. My intention is prune back the stream later on with a machine learning procedure. I will be carefully look not to overpass the 2,147,483,647 detected stream segments.
To reduce as much as possible I/O I save the *.tif file in the /dev/shm of each node, read then with r.external and build up the location on the flight in each /tmp. So, it quite fast. I will try to increase a bit the RAM.
Will post later how is going.
Best
Giuseppe
On 1 November 2017 at 17:12, Markus Metz <markus.metz.giswork@gmail.com> wrote:
Thanks Markus!!
Markus M
Best
Giuseppe
Markus M
Thank you
Best
New Haven, 06511
New Haven, 06511
New Haven, 06511
On Wed, Nov 1, 2017 at 10:41 PM, Giuseppe Amatulli <giuseppe.amatulli@gmail.com> wrote:
Thanks again!!
I forgot to mention that the unit of the threshold option is cells, not squared map units. That means you need to change the threshold value.
Markus M
Best
Giuseppe
Thanks Markus!!
Markus M
Best
Giuseppe
Markus M
Thank you
Best
New Haven, 06511
New Haven, 06511
New Haven, 06511
Hi Markus,
I have compile the GRASS7.2.3svn
r.stream.extract elevation=elv accumulation=upa threshold=0.5 depression=dep direction=dir stream_raster=stream memory=45000 --o --verbose
with a small area
expr 600 * 310 = 186 000 and everything works fine.
If I enlarge the area
expr 72870 * 80040 = 5 832 514 800
I get the following warning
16.67% of data are kept in memory
Initializing A* search…
0…WARNING: Segment pagein: read EOF
WARNING: segment lib: put: pagein failed
WARNING: Unable to write segment file
and than the stream is not created.
Is something due with compile of the GRASS7.2.3svn ?
or something else?
Concerning the threshold: I’m using area-flow-accumulation expressed in km2. So this means that each pixel have a value of the upper stream sum-area in km2. So if I fix the threshold to 0.5 means that my stream will start when all the cells below have value > 0.5. I have check and look correct to me, in fact my smallest upper stream basin have 7 cell 90*90 ( ~ 1/2 km2).
Thank you
Giuseppe
On 1 November 2017 at 17:52, Markus Metz <markus.metz.giswork@gmail.com> wrote:
Thanks again!!
Markus M
Best
Giuseppe
Thanks Markus!!
Markus M
Best
Giuseppe
Markus M
Thank you
Best
New Haven, 06511
New Haven, 06511
New Haven, 06511
New Haven, 06511
Teaching: http://spatial-ecology.net
On Wed, Nov 8, 2017 at 3:47 PM, Giuseppe Amatulli <giuseppe.amatulli@gmail.com> wrote:
Hi Markus,
with a small area
There was a small bug in the segment library, fixed in trunk r71648. You will need to update your local copy of GRASS 7.3.
Markus M
or something else?
Thank you
Giuseppe
Thanks again!!
Markus M
Best
Giuseppe
Thanks Markus!!
Markus M
Best
Giuseppe
Markus M
Thank you
Best
New Haven, 06511
New Haven, 06511
New Haven, 06511
New Haven, 06511
On Wed, Nov 8, 2017 at 5:29 PM, Markus Metz <markus.metz.giswork@gmail.com> wrote:
Hi Markus,
with a small area
Now also fixed for GRASS 7.2 in r71649.
Markus M
Markus M
or something else?
Thank you
Giuseppe
Thanks again!!
Markus M
Best
Giuseppe
Thanks Markus!!
Markus M
Best
Giuseppe
Markus M
Thank you
Best
New Haven, 06511
New Haven, 06511
New Haven, 06511
New Haven, 06511
On Wed, Nov 1, 2017 at 10:12 PM, Markus Metz
Thanks Markus!!
1) now how much is the upper limit matrix cell number that
(Added as a note to
https://grasswiki.osgeo.org/wiki/GRASS_GIS_Performance#Some_benchmarks
best,
markusN
Hi Markus M.
I was testing the r.stream.extract for 2 tiff
  1. 80040 x 72870 = 5,832,514,800 i got the stream results - no error
  2. 80490 x 142690 = 11,485,118,100 i got the following error
A* Search…
0…2…/var/spool/slurmd/job6514787/slurm_script: line 80: 28925 Bus error r.stream.extract elevation=elv accumulation=upa threshold=0.5 depression=dep direction=dir stream_raster=stream memory=45000 --o --verbose
Do you think that is something with the slurm ram limitation or is something with the r.extract.stream?
If the the stream output have a number of stream segments larger than 2,147,483,647 what is happen?
Do I get an error or all the value larger than 2,147,483,647 are just rounded to 2,147,483,647 ?
Moreover, if use the stream obtain from option 1) and I use the stream as input for the r.stream.basins
I got the following error
reading raster map …
0…3…6…9…12…15…18…21…24…27…30…33…36…39…42…45…/var/spool/slurmd/job6514788/slurm_script: line 82: 17687 Bus error /gpfs/home/fas/sbsc/ga254/.grass7/addons/bin/r.stream.basins -l stream_rast=stream direction=dir
is this something that need to be fixed in r.stream.basins, or should i think that is due to other problems
Thank you
Giuseppe
Thanks Markus!!
(Added as a note to
best,
markusN
New Haven, 06511
Hello
I think it was already mentioned in this thread: the threshold=0.5 is certainly wrong. The threshold value is number of pixels for minimum basin size. Usually it would be in the thousands. With your region size of 11 billion you probably want a threshold of tens of thousands.
On 11/16/2017 11:51 PM, Giuseppe Amatulli wrote:
Hi Markus M.
A* Search…
Thank you
Giuseppe
Thanks Markus!!
(Added as a note to
best,
markusN
New Haven, 06511
[grass-user@lists.osgeo.org](mailto:grass-user@lists.osgeo.org)
[https://lists.osgeo.org/mailman/listinfo/grass-user](https://lists.osgeo.org/mailman/listinfo/grass-user)
Micha Silver
Ben Gurion Univ.
Sde Boker, Remote Sensing Lab
cell: +972-523-665918
On Fri, Nov 17, 2017 at 7:52 AM, Micha Silver <tsvibar@gmail.com> wrote:
Hello
Hi Markus M.
A* Search…
As Giuseppe explained previously, accumulation has been rescaled to square kilometers, therefore the threshold is ok (still a bit small, but not nonsense).
Markus M
Thank you
Giuseppe
Thanks Markus!!
(Added as a note to
best,
markusN
New Haven, 06511
Micha Silver
Ben Gurion Univ.
Ah, I missed that, thanks
Hello
Markus M
Micha Silver
Ben Gurion Univ.
On Thu, Nov 16, 2017 at 10:51 PM, Giuseppe Amatulli <giuseppe.amatulli@gmail.com> wrote:
Hi Markus M.
Great, that means large maps with more than 2 billion cells are supported.
  1. 80490 x 142690 = 11,485,118,100 i got the following error
A* Search…
From wikipedia:
“a bus error is a fault raised by hardware, notifying an operating system (OS) that a process is trying to access memory that the CPU cannot physically address: an invalid address for the address bus, hence the name.”
I guess you either need to raise the RAM limit in slurm or slightly reduce the memory option for r.stream.extract.
Markus M
Thank you
Giuseppe
Thanks Markus!!
(Added as a note to
best,
markusN
New Haven, 06511
Hi Markus M,
I re-tested (size 80490 x 142690 = 11,485,118,100 ) r.stream.extract & r.stream.basins setting 25G RAM for the 2 commands with a slurm upper limit of 60G RAM.
The r.stream.extract use this RAM
On 17 November 2017 at 03:33, Markus Metz <markus.metz.giswork@gmail.com> wrote:
Hi Markus M.
A* Search…
From wikipedia:
Markus M
Thank you
Giuseppe
Thanks Markus!!
(Added as a note to
best,
markusN
New Haven, 06511
New Haven, 06511
Just finished the test with 100G and the computation finish without error.
So my conclusion is:
even if setting the max value of RAM in the r.stream.basins to memory=25000 the effective requirements is a bit less the then 100G.
A similar situation happens with r.stream.extract where the requested used RAM is a bit less then 50G.
Any thoughts?
Thanks you
Best
Giuseppe
On 26 November 2017 at 20:33, Giuseppe Amatulli <giuseppe.amatulli@gmail.com> wrote:
Hi Markus M,
JobID MaxVMSize
6731334.bat+ 47459272K
and finish without problem
rather r.stream.basins use
JobID MaxVMSize
6731334.bat+ 90241708K
and get kill with this error.
Reading raster map …
0…3…6…9…12…15…/var/spool/slurmd/job6731334/slurm_script: line 88: 15041 Bus error /gpfs/home/fas/sbsc/ga254/.grass7/addons/bin/r.stream.basins -l stream_rast=stream direction=dir basins=lbasin memory=25000 --o --verbose
I think something is implemented different in r.stream.basins compare to r.stream.extract.
I will try to ask for more RAM (100G) but I’m afraid that is going to fail again.
Any thoughts?
Thanks you
Best
Giuseppe
Hi Markus M.
A* Search…
From wikipedia:
Markus M
Thank you
Giuseppe
Thanks Markus!!
(Added as a note to
best,
markusN
New Haven, 06511
New Haven, 06511
New Haven, 06511
On Mon, Nov 27, 2017 at 3:56 AM, Giuseppe Amatulli <giuseppe.amatulli@gmail.com> wrote:
For r.stream.basins you need to use the -m flag, otherwise everything is done in RAM. A nice enhancement for all affected r.stream.* modules would be to switch automatically to disk swap mode if the amount of memory needed for all-in-RAM processing is larger than what is allocated with the memory=MB option.
This is strange. In my tests, r.stream.extract always uses a bit less than what is given with the memory option. I could process a raster with 11,612,160,000 cells and memory=25000 and actual peak memory consumption was about 24000 MB.
Markus M
Any thoughts?
Thanks you
Best
Giuseppe
Hi Markus M,
JobID MaxVMSize
JobID MaxVMSize
Any thoughts?
Thanks you
Best
Giuseppe
Hi Markus M.
A* Search…
From wikipedia:
Markus M
Thank you
Giuseppe
Thanks Markus!!
(Added as a note to
best,
markusN
New Haven, 06511
New Haven, 06511
New Haven, 06511
