On Wed, Aug 29, 2012 at 1:28 PM, Micha Silver <micha@arava.co.il> wrote:
Hi Markus,
Thanks for responding. I still can't seem to get this to work.
Here are my steps:
r.stream.extract elev=dtm thresh=500000 stream_rast=stream_500
stream_vect=stream_500 dir=fdir_500
r.stream.order stream=stream_500 dir=fdir_500 table=stream_order
v.db.connect map=stream_500 driv=sqlite table=stream_order key=cat layer=2
Here I get:
The table <stream_order> is now part of vector map <stream_500> and may be
deleted or overwritten by GRASS modules
DBMI-SQLite driver error:
Cannot create index:
create unique index stream_order_cat on stream_order ( cat )
index stream_order_cat already exists
WARNING: Cannot create index
Select privileges were granted on the table
Next:
v.category stream_500 opt=report layer=2
Layer/table: 1/stream_500
type count min max
point 248 1 237
line 237 1 237
boundary 0 0 0
centroid 0 0 0
area 0 0 0
all 485 1 237
Layer/table: 2/stream_order
type count min max
point 248 0 2
line 237 0 1
boundary 0 0 0
centroid 0 0 0
area 0 0 0
all 485 0 2
Why in layer 2 are there only 2 cat values?
Because
"In layer 1, categories are unique IDs,
identical to the cell value of the raster output. The attribute table
for layer 1 holds information about the type of stream segment: start
segment, or intermediate segment with tributaries. Columns are cat int,
stream_type varchar(), type_code int. The encoding for type_code is 0 =
start, 1 = intermediate. In layer 2, categories are identical to
type_code in layer 1 with additional category 2 = outlet for outlet
points. Points with category 1 = intermediate in layer 2 are at the
location of confluences."
Shouldn't I get all the cats as
in layer 1 when I use "key=cat" in the v.db.connect??
No, v.db.connect connects a table to a vector layer. It does not
modify the vector layer.
Do I need to delete
and recreate the cats in layer 2 ?
No. Simply connect the table to layer 1, this should give you the
desired result.
And finally, the export:
GRASS 6.4.2 (ITM):~/GIS/DEM/LIDAR_EinYahav > v.out.ogr -c -e stream_500
type=line dsn=stream_500.shp layer=2
WARNING: 248 point(s) found, but not requested to be exported. Verify
'type' parameter.
Exporting 485 geometries...
WARNING: 124 features without attributes were written
v.out.ogr complete. 237 features written to <stream_500> (ESRI_Shapefile).
Why am I getting 485 geometries?
This is probably a bogus message. There are a total of 485 geometries
in the vector, 248 points and 237 lines. As the last message of
v.out.ogr says, 237 features were written.
and why are 124 with no attributes?
Because you exported layer 2, where cat=0 is a valid cat, but the
table you attached to layer 2 does not have an entry for cat=0.
Markus M
On 08/28/2012 11:15 PM, Markus Metz wrote:
On Tue, Aug 28, 2012 at 9:05 PM, Micha Silver<micha@arava.co.il> wrote:
A few more details regarding v.out.ogr when layer=2
I see this ticket, possibly similar:
http://trac.osgeo.org/grass/ticket/991
I tried to export to PostGIS, and again, all attribute fields are created
but all values are NULL. I also tried with the layer 2 database as a dbf
file, instead of sqlite. Same result.
This was all with GRASS 6.4.2 on scientific linux 6
What does v.category op=report say? Are there any categories in layer
2? If not, there is nothing to export.
Markus M
Micha
On 08/28/2012 02:57 PM, Micha Silver wrote:
I'm having two problems when exporting the output of r.stream.order to a
shapefile.
I have attached the created table (saved in my setup in sqlite) to the
'streams' map thru layer 2. Then
v.db.select streams layer=2
shows all the details of strahler order, prev_str, etc.
First problem: When I try to do v.out.ogr, the column header named
"next_stream" fails because it's 10 characters long, too long for a
shapefile dbf. As a result all attributes are missing. Here's a patch to
io.c in r.stream.order I put in place to correct this:
[micha@SL6 r.stream.order]$ diff -u io.c.orig io.c
--- io.c.orig 2012-08-28 12:21:46.020275045 +0300
+++ io.c 2012-08-28 12:22:17.951382882 +0300
@@ -292,7 +292,7 @@
/* table definition */
char *tab_cat_col_name = "cat integer";
char *tab_stream = "stream integer";
- char *tab_next_stream = "next_stream integer";
+ char *tab_next_stream = "next_str integer";
char *tab_prev_streams;
char *tab_strahler = "strahler integer";
char *tab_horton = "horton integer";
@@ -300,7 +300,7 @@
char *tab_hack = "hack integer";
char *tab_length = "length double precision";
char *tab_cumlength = "cum_length double precision";
- char *tab_stright = "stright double precision";
+ char *tab_stright = "straight double precision";
char *tab_fractal = "fractal double precision";
char *tab_distance = "out_dist double precision";
char *tab_topo_dim = "topo_dim integer";
(Also corrects a small typo in the column name "stright")
After recompiling, then rerunning the r.stream.order addon, the sqlite
table
now has all column headers<= 10 characters suitable to shapefile.
Problem 2, where I'm stuck. I export the vector map using :
v.out.ogr streams layer=2 dsn=streams.shp
The process finishes OK, and the shape is created with all attrib
columns,
but *all* values are NULL (including the cat). Any ideas what I've done
wrong?
Micha
This mail was received via Mail-SeCure System.
grass-user mailing list
grass-user@lists.osgeo.org
Micha Silver
GIS Consultant, Arava Development Co.
http://www.surfaces.co.il
