[GRASS-user] r.stream.order (GRASS 6), Hack, fails at some confluences
Hi everyone,
Does anyone have experience with r.stream.order failing at some stream confluences for Hack ordering, such that the rest of stream network upstream gets assigned an order of -1?
When I re-run the algorithm starting just upstream of the confluence, it works. I have seen many instances of this type of failure. Please let me know if you have any ideas on why it might be happening and what I can about it.
Thank you very much,
Hanan
This message has been scanned for malware by Websense. www.websense.com
