Hei,
I'm a new grass user and I can't manage to install r.stream.order
addon on my mac OSX v.10.9.5. Installed Grass GIS 6.4, which runs
fine. What am I doing wrong?
Thanks in advance!
Error message:
(Mon Sep 29 11:46:38 2014)
g.extension.py extension=r.stream.order
svnurl=http://svn.osgeo.org/grass/grass-addons/grass6
GRASS_ADDON_PATH has more items, using first defined -
'/Users/snarrald/Library/GRASS/6.4/Modules/bin'
Fetching <r.stream.order> from GRASS-Addons SVN (be patient)...
Compiling...
/Applications/GRASS-6.4.app/Contents/MacOS/include/Make/Modu
le.make:25: warning: overriding commands for target
`install'
/Applications/GRASS-6.4.app/Contents/MacOS/include/Make/Rule
s.make:90: warning: ignoring old commands for target
`install'
io.c:1:10: fatal error: 'grass/glocale.h' file not found
#include <grass/glocale.h>
1 error generated.
make: *** [OBJ.i386-apple-darwin11.4.0/io.o] Error 1
ERROR: Compilation failed, sorry. Please check above error messages.
(Mon Sep 29 11:46:48 2014) Command finished (9 sec)
Does other r.stream.* addons install without issues?
2014-09-29 15:18 GMT-05:00 Svein Harald Sønderland <snarrald@gmail.com>:
Hei,
I’m a new grass user and I can’t manage to install r.stream.order
Thanks in advance!
Error message:
‘/Users/snarrald/Library/GRASS/6.4/Modules/bin’
Fetching <r.stream.order> from GRASS-Addons SVN (be patient)…
Compiling…
install' /Applications/GRASS-6.4.app/Contents/MacOS/include/Make/Rule s.make:90: warning: ignoring old commands for target
install’
io.c:1:10: fatal error: ‘grass/glocale.h’ file not found
1 error generated.
grass-user mailing list
grass-user@lists.osgeo.org
César Augusto Ramírez Franco
Laboratorio de Sistemas Complejos Naturales
Escuela de Geociencias
Facultad de Ciencias
Universidad Nacional de Colombia - Sede Medellín
Teléfono: (57-4) 430 9369 - 300 459 6085
Hei,
No, all r.stream*addons seem to have the same issue.
On Wed, Oct 1, 2014 at 6:04 PM, César Augusto Ramírez Franco
Hei,
Thanks in advance!
Error message:
Compiling...
`install'
`install'
1 error generated.
