[GRASS-user] r.sun.daily with multiple CPU cores: error uncompressing raster data ...
Hi everyone,
First of all, thanks in advance for the r.sun.daily module which is a
nice replacement for my amateurish attempts over the last 12 years.
I am currently working on an annual beam radiance map for a large
geographic region, at 30m res: 70,953 x 46,964 cells. This is far too
large for a single pass of r.horizon or r.sun on my machine so I have
split the data into 5,000 x 5,000 cell tiles with 100 cells of
overlap. This seems to be sufficient for my purposes and the edge
effects are tolerable.
At 8-15 minutes / tile / day (r.sun) and 54 tiles this job calls for
multiple CPU cores. All of the parallel processing that I use is (as
far as I know) contained within the same region.
I have had good success with running r.horizon in parallel via GNU
parallel like this:
# 1: start angle
# 2: angle step
# 3: elevation tile
seq 0 $step 330 | parallel --gnu --progress "bash make-hz-maps.sh {}
$step $elev"
Which is just a wrapper around r.horizon and run in parallel "within" tiles.
Next, I run r.sun.daily (8 CPU cores) within tiles:
r.sun.daily --overwrite elevation=$elev aspect=$asp slope=$slope \
start_day=1 end_day=365 beam_rad=$beam horizon_basename=hzangle
horizon_step=$step nprocs=8
The r.sun.daily modules finishes without error about 50-60% of the
time, results look good. The other 50-40% of the the time I get this:
ERROR: Error uncompressing raster data for row 2605 of
       <r_sun_crop8255_beam_rad_tmp_352>
*** buffer overflow detected ***: g.message terminated
======= Backtrace: =========
/lib/x86_64-linux-gnu/libc.so.6(+0x7329f)[0x7f8b9a70129f]
/lib/x86_64-linux-gnu/libc.so.6(__fortify_fail+0x5c)[0x7f8b9a79c83c]
/lib/x86_64-linux-gnu/libc.so.6(+0x10d710)[0x7f8b9a79b710]
/lib/x86_64-linux-gnu/libc.so.6(+0x10cc19)[0x7f8b9a79ac19]
/lib/x86_64-linux-gnu/libc.so.6(_IO_default_xsputn+0xbc)[0x7f8b9a70961c]
/lib/x86_64-linux-gnu/libc.so.6(_IO_vfprintf+0x1cc5)[0x7f8b9a6d9905]
/lib/x86_64-linux-gnu/libc.so.6(__vsprintf_chk+0x84)[0x7f8b9a79aca4]
/usr/local/grass-7.5.svn/lib/libgrass_gis.7.5.svn.so(+0x1343c)[0x7f8b9aa6a43c]
/usr/local/grass-7.5.svn/lib/libgrass_gis.7.5.svn.so(G_fatal_error+0xbf)[0x7f8b9aa6accf]
g.message(main+0x254)[0x400dd4]
/lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf5)[0x7f8b9a6aff45]
g.message[0x400ea2]
I can't seem to replicate the problem, as subsequent runs with the
same parameters and in the same tile are successful! This leads me to
think that:
* some aspect of this approach is not thread safe
* there is something wrong with my computer
* there is a subtle bug in the raster writing / reading code when
invoked in parallel
I have encountered similar raster reading errors in the past,
typically in the context of parallel processing:
https://trac.osgeo.org/grass/ticket/2762
https://trac.osgeo.org/grass/ticket/2764
http://osgeo-org.1560.x6.nabble.com/Error-reading-raster-data-for-row-xxx-only-when-using-r-series-and-t-rast-series-td5229569i20.html
https://lists.osgeo.org/pipermail/grass-dev/2015-July/075691.html
Here is some information on my system and version of GRASS:
./configure --enable-64bit --with-libs=/usr/lib --without-pthread
--without-odbc --without-mysql --with-readline --with-cxx
--enable-largefile --with-freetype
--with-freetype-includes=/usr/include/freetype2 --with-sqlite
--with-python --with-geos=/usr/local/bin/geos-config --without-opencl
--with-opencl-includes=/usr/include/CL/ --with-postgres
--with-postgres-includes=/usr/include/postgresql/
--with-postgres-libs=/usr/lib/
--with-proj-share=/usr/local/share/proj/
version=7.5.svn
date=2017
revision=r71964
build_date=2017-12-21
build_platform=x86_64-pc-linux-gnu
build_off_t_size=8
Any ideas?
I haven't had a chance to inspect the maps in question as r.sun.daily
deletes the intermediate pieces on error.
Thanks!
Dylan
On Fri, Dec 29, 2017 at 5:07 PM, Dylan Beaudette <dylan.beaudette@gmail.com> wrote:
Hi everyone,
parallel like this:
1: start angle
2: angle step
3: elevation tile
seq 0 $step 330 | parallel --gnu --progress “bash make-hz-maps.sh {}
$step $elev”
Which is just a wrapper around r.horizon and run in parallel “within” tiles.
g.message[0x400ea2]
I can’t seem to replicate the problem, as subsequent runs with the
think that:
  • some aspect of this approach is not thread safe
  • there is something wrong with my computer
  • there is a subtle bug in the raster writing / reading code when
    invoked in parallel
–without-odbc --without-mysql --with-readline --with-cxx
–enable-largefile --with-freetype
–with-freetype-includes=/usr/include/freetype2 --with-sqlite
–with-python --with-geos=/usr/local/bin/geos-config --without-opencl
–with-opencl-includes=/usr/include/CL/ --with-postgres
–with-postgres-includes=/usr/include/postgresql/
–with-postgres-libs=/usr/lib/
–with-proj-share=/usr/local/share/proj/
version=7.5.svn
date=2017
revision=r71964
build_off_t_size=8
Any ideas?
Please try the patch attached to ticket #2764 helps to get closer to the problem.
Markus M
I haven’t had a chance to inspect the maps in question as r.sun.daily
Thanks!
Dylan
grass-user mailing list
grass-user@lists.osgeo.org
On Sat, Dec 30, 2017 at 2:32 PM, Markus Metz
wrote:
Hi everyone,
parallel like this:
# 1: start angle
# 2: angle step
# 3: elevation tile
$step $elev"
tiles.
g.message[0x400ea2]
think that:
invoked in parallel
version=7.5.svn
date=2017
revision=r71964
build_off_t_size=8
Any ideas?
problem.
Markus M
Hi Markus,
Thank you for the quick reply and patch. I have recompiled with the
patch from #2764 and now waiting to see what happens.
Happy New Year!
Dylan
Dang, this appears to be happening with any module run in parallel
that generates FCELL or DCELL maps. In this case, r.horizon run in
parallel.
I have added additional commentary to #2764
https://trac.osgeo.org/grass/ticket/2764#comment:9
After application of Markus' latest patch the error message is now
"Decompression failed with error 0".
Dylan
On Sat, Dec 30, 2017 at 9:34 PM, Dylan Beaudette
wrote:
Hi everyone,
parallel like this:
# 1: start angle
# 2: angle step
# 3: elevation tile
$step $elev"
tiles.
g.message[0x400ea2]
think that:
invoked in parallel
version=7.5.svn
date=2017
revision=r71964
build_off_t_size=8
Any ideas?
problem.
Markus M
Hi Markus,
Happy New Year!
Dylan
Update: after applying the latest patch, I now see
ERROR: Decompression failed with error -1
I found the map that fails decompression. Is there any way to inspect
the map in order to search for more clues as to what is wrong with it
or how it might have happened?
All of the maps in this project are using the default ZLIB
compression, along with compressed NULL files. Looking over the zlib
manual (https://www.zlib.net/manual.html), I see several references to
an error code of "-1":
#define Z_ERRNO (-1)
Z_ERRNO if there is an error writing the flushed data
Z_ERRNO on a file operation error
ZEXTERN const char * ZEXPORT gzerror OF((gzFile file, int *errnum));
Returns the error message for the last error which occurred on the
given compressed file. errnum is set to zlib error number. If an error
occurred in the file system and not in the compression library, errnum
is set to Z_ERRNO and the application may consult errno to get the
exact error code.
The last note is interesting and suggests that this specific "problem"
may be happening at the file system or OS level. That said, I have
only encountered this error in the context of FCELL or DCELL
maps--which makes me think that it is some combination of GRASS and
the underlying file system.
Some OS information:
3.13.0-106-generic #153-Ubuntu SMP Tue Dec 6 15:44:32 UTC 2016 x86_64
x86_64 x86_64 GNU/Linux
Description: Ubuntu 14.04.5 LTS
Release: 14.04
Thanks!
Dylan
On Sat, Dec 30, 2017 at 9:51 PM, Dylan Beaudette
parallel.
Dylan
wrote:
Hi everyone,
parallel like this:
# 1: start angle
# 2: angle step
# 3: elevation tile
$step $elev"
tiles.
g.message[0x400ea2]
think that:
invoked in parallel
version=7.5.svn
date=2017
revision=r71964
build_off_t_size=8
Any ideas?
problem.
Markus M
Hi Markus,
Happy New Year!
Dylan
