Hy!
For a thesis I have to calculate monthly and yearly sums of solar energy. To
facilitate me the process I thought of using a script for that (first time
for me using a script in GRASS GIS). I found the script that can be seen in
the link below:
http://www.grassbook.org/scripts2nd/rsun_crop.sh.txt rsun_crop.sh
I tried to execute this script, but without success.
Starting the script and setting the input parameters are not rising problems
I guess.
The first thing that comes up is:
"test.sh: line 50: 7593 Segmentation fault" --> Is this a kind of error
message and if yes, what´s the influence of it or what can I do to prevent
it?
Second I get the ERROR that the maps I´m trying to create (for beam, diff
and ref irradiance) are "not found in the current" mapset and that they are
"not found". I first thought that I have to prepare these map before
starting the script, but also when I prepared the maps, it didn´t work.
See screenshot of my bash:
http://osgeo-org.1803224.n2.nabble.com/file/n6203754/Screen_shot_2011-03-24_at_06.27.48.png
Hope someone can help me.
Tim
View this message in context: http://osgeo-org.1803224.n2.nabble.com/r-sun-run-script-tp6203754p6203754.html
it?
I guess the first error message has something to do with my OS. I´m using
Mac OS X 10.6. When I start the script on Windows XP "only" the second error
message still exists.
are "not found". I first thought that I have to prepare these map before
Tim
View this message in context: http://osgeo-org.1803224.n2.nabble.com/r-sun-run-script-tp6203754p6203977.html
On Thu, Mar 24, 2011 at 12:41 PM, TimNorwey <timmy_weyrer@live.at> wrote:
Hy!
the link below:
Better execute it with the -x flag to obtain detailed output:
sh -x rsun_crop.sh
I guess.
it?
That means that r.sun crashed for some reasons to be understood.
Any other Mac OS X 10.6 user in this list who could try to run the
script?
They are the output of the r.sun run. Since it crashed, no output...
Consider to post such output as text here for example (easier to read):
http://osgeo.pastebin.com/
sh -x rsun_crop.sh
thanks for the hint
I hope you meant it like that:
http://pastebin.com/DbBuyD7t pastebin rsun_crop.sh output
thanks,
tim
View this message in context: http://osgeo-org.1803224.n2.nabble.com/r-sun-run-script-tp6203754p6206151.html
Hey.
Now I think I got it. It´s all about the latitude. Just take a look on the
manual http://grass.osgeo.org/grass62/manuals/html62_user/r.sun.html r.sun
manual :
"...There is no need to define latitude for locations with known and defined
projection/coordinate system..."
Only while running r.sun with a defined latitude, the error occurred. And
I´m pretty sure that I a defined a valid latitude for my location.
So what do you all think about that?
And has anyone else tried to run the script on other OS? With and without
defining latitude?
Would be good to know if the error occurs only on Mac OS or also on other
system.
Here is current working script:
http://osgeo-org.1803224.n2.nabble.com/file/n6206439/r_sun_Tim.sh
r_sun_Tim.sh
Tim
View this message in context: http://osgeo-org.1803224.n2.nabble.com/r-sun-run-script-tp6203754p6206439.html
I´m pretty sure that I defined a valid latitude for my location.
defining latitude?
system.
I adapted my script a little bit. Here it is:
http://osgeo-org.1803224.n2.nabble.com/file/n6212908/rsun_script_TimNorwey.sh
And I´m still interested to get some answers to my questions ;-)...
cheers,
tim
View this message in context: http://osgeo-org.1803224.n2.nabble.com/r-sun-run-script-tp6203754p6212908.html
Please repost the error here.
defining latitude?
system.
The whole error file can be seen here: http://pastebin.com/DbBuyD7t
pastebin_error_output
defining latitude?
system.
cheers,
tim
View this message in context: http://osgeo-org.1803224.n2.nabble.com/r-sun-run-script-tp6203754p6216204.html
